				 Posted: Thu Aug 09, 2007 8:16 am    Post subject: W&B |
				Boyd,
 Big Lar has suggested that you have contrived an inexpensive radio ariel.
 Can you let me have details please.
 Pat
 Off list if you like  pj.ladd(at)btinternet.com
		Richard Pike
				 Posted: Thu Aug 09, 2007 10:44 am    Post subject: W&B |
				Here it is, pretty simple to make. Good luck.
 http://www.bcchapel.org/pages/0003/pg9.htm
 Richard Pike
 MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
				 Posted: Thu Aug 09, 2007 12:55 pm    Post subject: W&B |
				pretty simple to make. >>
 Famous last words.  To me anything electrical that you dont push into a
 socket and switch it on , is complicated..  However my ex partner in the
 Eurostar builds his own  model railway stuff and has a little workshop.
 Time to call in a favour I think.
 Thank you  and thank you to the several list members who have given me
 advice.  Thanks everybody
 Pat
				 Posted: Thu Aug 09, 2007 1:03 pm    Post subject: W&B |
				The spread sheet is not been made to look real purdy,,,,,   but it works.>>
 Boyd,
 I have tried without success to view and print this. I have not been able to
 produce a program to open an xls file.
 Is it possible to send it in another format ?
 Pat
		d-m-hague(at)comcast.net Guest
				 Posted: Thu Aug 09, 2007 7:39 pm    Post subject: W&B |
				At 05:03 PM 8/9/2007, you wrote:
  	  | Quote: | 	 		  I have tried without success to view and print this. I have not been able
 to produce a program to open an xls file.
 xls is Microsoft Excel, part of MS Office.  If you don't have that then the
 free software OpenOffice (http://openoffice.org) will do it.
                                  -Dana
 "The budget should be balanced, the Treasury should be refilled, public
 debt should be reduced, the arrogance of officialdom tempered and
 controlled, and the assistance to foreign lands should be curtailed lest
 Rome become bankrupt" -Cicero, 68 B.C.
				 Posted: Fri Aug 10, 2007 12:29 am    Post subject: W&B |
				xls is Microsoft Excel, >>
 Thanks Dana,
 I think Wendy has that on her confuser.
 Pat
		jenelson1(at)hotmail.com Guest
				 Posted: Fri Aug 10, 2007 5:31 am    Post subject: W&B |
				I finished my Kolb Firestar rework last night and  have a question.  My W&B is at 33% and the manual says it needs to be  at 20 to 37%.  My question is what are you guys getting for W&B and  being slightly tail heavy has anyone had any issues?  I would rather have  it a little tail heavy as I can lean forward to get out of any strange  situations.  When I had the Luscombe I was amazed at how things  changed on the plane when I just leaned forward a little.  I will be  calling for the inspection this PM.  I was happy with my weight, I  turned out to be 359 with full fuel and an electrical system w battery.  It  is still a pull start though.  That is another thing as the fuel is burned  off my W&B will change.  I guess I will do a W&B with the tank  empty tonight. If anyone is interested I can post the W&B. Let me know.  I also installed a IVO 2 blade prop.  I can't believe how much  smoother it runs over the old wood prop that was on it.
  Jeff Nelson
  Kolb Firestar KXP N1655E
		Thom Riddle
				 Posted: Fri Aug 10, 2007 6:36 am    Post subject: Re: W&B |
				Jeff,
 I get the impression from your post that you are talking about your CG without you, the pilot, sitting in the airplane. If I am interpreting your post incorrectly, sorry.
 However, if I'm interpreting it correctly, please note the following:
 The acceptable CG range is meaningful only with the aircraft loaded (you and fuel and gizmos you carry) and in flight stance, not tail on the ground. You should be interested in the CG location with you in the airplane and full fuel but also with you in the airplane and minimum fuel,  since you will use the fuel in flight. Your aircraft empty weight(no fuel) and CG location in flight stance is needed so you can calculate what various loading (different pilot weights) will do to the CG in flight. Your empty weight CG location does not have to be within the acceptable range, in fact rarely will be in a Kolb.
 I hope this clarifies the meaning and significance of the acceptable CG range numbers.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
				 Posted: Fri Aug 10, 2007 10:28 am    Post subject: W&B |
				Sorry yes I did include myself in the percentage calculation with full fuel
 and all the gizmo's and the empty weight I had included 5 gal of fuel so
 with me and everything the full weight is at 565 and my understanding from
 the paperwork I have this is within the gross weight.  I was just asking is
 where are other people at for their CG.  As you know this is a big part of
 the certification process and needs to be right.
 Jeff
 Reply-To: kolb-list(at)matronics.com
 Subject: Re: W&B
 Date: Fri, 10 Aug 2007 07:36:22 -0700
 Jeff,
 Kolb.
 range numbers.
 Thom in Buffalo
 N197BG FS1/447
 "Blind respect for authority is the greatest enemy of truth."
 Albert Einstein
 http://forums.matronics.com/viewtopic.php?p=128466#128466
 Learn.Laugh.Share. Reallivemoms is right place!
 http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
		Thom Riddle
				 Posted: Fri Aug 10, 2007 10:38 am    Post subject: Re: W&B |
				Jeff,
 My FS 1 CG is at 33.4% with full fuel and me, 33.0% with tank near empty.
Buffalo, NY (9G0)
- Anonymous |
		gaman(at)att.net Guest
				 Posted: Sat Aug 11, 2007 1:16 pm    Post subject: W&B |
				Thom,
           my FS 2 was at the aft end of the cg range also.probably because of a lot of paint including silver,white then aerothane which added at least 30 lbs to the plane plus at 170 (my wgt.) needed 10 bag of lead shot in the nose.It will feel a lot more stable if it's a little forward than aft.Throw some tire weight lead in a bag and try it out.I also raised the horizontal leading edge 3/4 of an inch with brackets to trim it out better.
          Been there,G.Aman FS2
 Thom Riddle <riddletr(at)gmail.com> wrote:[quote] --> Kolb-List message posted by: "Thom Riddle"
 Jeff,
 Thom in Buffalo
 N197BG [quote][b]
		by0ung(at)brigham.net Guest
				 Posted: Fri Aug 17, 2007 8:53 am    Post subject: W&B |
				For anyone that is interested....  I have redone my W&B spreadsheet in word
 perfect 8  ,,,  note that the spreadsheet will not calculate....  it is only
 useful to show you what entries to put in the cells of your spreadsheet
 program....
 Also converted it to asci text,,,   I did not line up the columns as well as
 I should have but it will let you know what to put into the cells of your
 spreadsheet program....  for ease of meaning I put the additions in long
 hand instead of using an    (at)sum    function...
 If you would like   I could forward the spread sheet in
 quarto pro
 excel
 dbase
 123
 Paradox
 I don't know how they will convert in other than the quarto pro and excel
 programs.
 Dbase   123   and paradox,,,,, you will be on your own.  Also if you have
 special requirements,,,, I can output in different versions of the listed
 software.
 Do not archive.
 Boyd
