head bolt torque : 20 or 24 ft.lbs???
avidflyer01
PostPosted: Fri Aug 17, 2007 12:51 pm    Post subject: head bolt torque : 20 or 24 ft.lbs??? Reply with quote
hi guys I am reassembling my engine (2200, s/n 2262, hyd lifters) after the replacement of valve guides.
the manual says : head bolts INITIALLY assembled at 24ft, check at 25hrs at 20ft - but if I removed and put back the head, should I assemble with 20 or 24ft.lbs??????
any "official" input? pete?
martin
avid flyer/jab2200
ultralight.flyer(at)gmail
PostPosted: Fri Aug 17, 2007 2:04 pm    Post subject: head bolt torque : 20 or 24 ft.lbs??? Reply with quote
24ft.lbs. Thats official information sent by Jabiru Australia to us.
On 8/17/07, avidflyer01 <vegayacht(at)club.fr (vegayacht(at)club.fr)> wrote: [quote]--> JabiruEngine-List message posted by: "avidflyer01" < vegayacht(at)club.fr (vegayacht(at)club.fr)>
martin
avid flyer/jab2200
http://forums.matronics.com/viewtopic.php?p=129635#129635
Cel.: +351 91 419 21 04
e-Mail: ultralight.flyer(at)gmail.com (ultralight.flyer(at)gmail.com) [quote][b]
t_fogelson(at)yahoo.com
PostPosted: Fri Aug 17, 2007 7:10 pm    Post subject: head bolt torque : 20 or 24 ft.lbs??? Reply with quote
Not official input, but if it were my engine, I would
start with the original torque setting. You also
should see if you need to replace the head bolts.
Contact the Jabiru rep for the official skinny.
Terry
--- Miguel Maia de Loureiro
Australia to us.
On 8/17/07, avidflyer01 <vegayacht(at)club.fr> wrote:
"avidflyer01" <vegayacht(at)club.fr>
> martin
> avid flyer/jab2200
Ultralight Pilot Suport Services
http://get.games.yahoo.com/proddesc?gamekey=monopolyherenow
andy(at)suncoastjabiru.co
PostPosted: Sat Aug 18, 2007 4:05 am    Post subject: head bolt torque : 20 or 24 ft.lbs??? Reply with quote
Martin,
Use 24ft/lbs for initial assembly and then check thereafter at 20/22ft/lbs.
The lower setting is simply to check for problems, not to move the bolt(s)
if torque remains at the higher value.
Andt
Suncoast Sportplanes, Inc.
39248 South Ave, Zephyrhills, FL 33542
Tel: (813) 779 2324 Fax: (813) 779 2246
www.suncoastjabiru.com
avidflyer01
PostPosted: Sat Aug 18, 2007 11:51 am    Post subject: Re: head bolt torque : 20 or 24 ft.lbs??? Reply with quote
thanks Andy and all
martin
