M-14 AUTO FUEL
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
btripp(at)interisland.net
PostPosted: Sat Aug 18, 2007 11:27 am    Post subject: M-14 AUTO FUEL Reply with quote
Is it possible to run the M14 on auto fuel? I've heard rumors that it
is possible, but I can't find anything in print on it. If it is
possible, what modifications have to be made to the engine?
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
ScottA
PostPosted: Sat Aug 18, 2007 2:01 pm    Post subject: M-14 AUTO FUEL Reply with quote
I know of 5 or 6 Moose running on auto fuel and a few of the YAK guys too.
You won't find any 'official' information in print - only opinions.
http://www.goflyamoose.com/main_pages/m14faq.shtm#m14faq3
No modifications required. Just no alcohol like all the actual STC's.
Scott
cliff(at)gesoco.com
PostPosted: Mon Aug 20, 2007 12:12 pm    Post subject: M-14 AUTO FUEL Reply with quote
It is possible to run the M-14P on Autofuel with some caveats.
Remember the whole point of octane rating is to suppress detonation and
pre-ignition.
As compression rating increases, the risk of detonation and pre-ignition
increases. Therefore in high compression engines or engines which
increase the manifold pressure (supercharged and turbocharged engines) a
higher octane rating is required.
Motorstar (the current engine manufacturer) recommends an MON octane
rating of no less than 91.
Automotive gasoline is rated by the RON+MON/2 method.
Aviation gasoline is rated by rich operating mixture/ lean operating
mixture (ie. 100/130)
Therefore I don't recommend using an automotive fuel of less than 94 octane.
As stated previously, do not use auto fuel which contains alcohol..for a
number reasons.
Most notably, it will attack the seals and diaphragms in the fuel system.
Finally, I would recommend that if autofuel is used, that it's mixed
with Avgas because:
1) The Avgas will raise the octane rating.
2) Avgas is very stable and will not degrade like autofuel.
Hope this helps!
Cliff Coy
Gesoco Industries
bob tripp wrote:
<btripp(at)interisland.net>
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
