LSE Direct crank vs. Hall effect
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
baremetl(at)gvtc.com
PostPosted: Sat Aug 18, 2007 5:41 pm    Post subject: LSE Direct crank vs. Hall effect Reply with quote
After nearly 1400 hrs.and 4 mag failures (Slick), I am considering an LSE unit to replace the right mag. I realize that the direct crank sensor is less expensive and that the Hall effect sensor that mounts in the old mag position is simpler to install. Ignoring the cost difference and initial installation difference, is there any other reason to pick one over the other? I am looking for comments on reliability of one sensor vs. the other and any other pertinent information.
Ivan Haecker -4 1381 hrs. S. Cen. TX
ps 3 failed coils and 1 failed condensor. And yes I used blast tubes (after the 1st failure!)
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
smokyray(at)yahoo.com
PostPosted: Mon Aug 20, 2007 6:36 pm    Post subject: LSE Direct crank vs. Hall effect Reply with quote
1500 hours on my Electroair ignition...give them a call.
www.electroair.net
Rob Ray
"H.Ivan Haecker" <baremetl(at)gvtc.com> wrote:[quote] After nearly 1400 hrs.and 4 mag failures (Slick), I am considering an LSE unit to replace the right mag. I realize that the direct crank sensor is less expensive and that the Hall effect sensor that mounts in the old mag position is simpler to install. Ignoring the cost difference and initial installation difference, is there any other reason to pick one over the other? I am looking for comments on reliability of one sensor vs. the other and any other pertinent information.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
