		Guy Buchanan
				 Posted: Sat Aug 18, 2007 1:44 pm    Post subject: Rotax Voltage Regulator |
				All,
          It looks like my Rotax 582 three phase voltage regulator's
 dying. (It will occasionally go over voltage. I can re-set it and get
 it to work, but it's happening more often now.)
          Does anyone have a recommended replacement? I've mounted it
 in the engine compartment to minimize electrical noise in the cockpit
 and I suspect things are a little hot for the stock Rotax unit. Has
 anyone tried any of the Harley replacements? Any after-market units?
 Or should I just increase the cooling to the Rotax unit?
 Guy Buchanan
 San Diego, CA
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Deceased K-IV 1200
A glider pilot too. |
		jetboy
				 Posted: Sat Aug 18, 2007 3:53 pm    Post subject: Re: Rotax Voltage Regulator |
				Guy,
 Are you sure its not the battery geeting aged. regulators dont usually deteriorate in the way you describe, but a poor internal resistance battery may bring on the symptom.
 Ralph
  _________________ Ralph - CH701 / 2200a |
		Guy Buchanan
				 Posted: Sat Aug 18, 2007 5:35 pm    Post subject: Rotax Voltage Regulator |
				At 04:53 PM 8/18/2007, you wrote:
  	  | Quote: | 	 		  Are you sure its not the battery geeting aged. regulators dont
 I'm intrigued, since this battery has been nearly dead twice and
 resurrected with a BatteryMinder. I read Bob's section on regulator
 failures and it seems like the over-voltage condition should be
 permanent, and not intermittent. (It seems like it doesn't work when
 cold, then with my switching it in and out it finally starts to
 regulate the voltage. Once it's working it never quits. And if I
 re-start it seems to work fine.) I'll dig into Bob's book to try to
 find an easy way to check internal resistance.
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
		nuckollsr(at)cox.net Guest
				 Posted: Sat Aug 18, 2007 9:31 pm    Post subject: Rotax Voltage Regulator |
				At 06:26 PM 8/18/2007 -0700, you wrote:
 failures and it seems like the over-voltage condition should be permanent,
 and not intermittent. (It seems like it doesn't work when cold, then with
 my switching it in and out it finally starts to regulate the voltage. Once
 it's working it never quits. And if I re-start it seems to work fine.)
 I'll dig into Bob's book to try to find an easy way to check internal
 resistance.
 Guy Buchanan
    Intermittent voltage excursions both upward and downward
    are manifestations of ageing components and/or internal
    connections that have become less than the best we know
    how to do.
    I believe John Deere (and others) offer a 3-phase
    rectifier/regulator for their 25-40 amp PM alternators.
    I searched the web hoping to find some maintenance
    data or at least some part numbers. No joy.
    Anyone out there have some experience with the larger
    3-phase PM alternator products.
    I've got to visit a customer Monday on the west side
    of town near a John Deere dealership. I'll see if there's
    a helpful individual there who can give me more data
    on the larger PM alternator systems.
    Now, this is an excellent DIY project. We've explored
    the inner workings of the various PM alternator rectifier/
    regulators. I've taken an exemplar single phase R/R
    schematic and added the SCR and diode to accommodate
    a 3 phase alternator. It's posted at:
 http://www.aeroelectric.com/Pictures/Schematics/3-Phase_PM_Rectifier_Regulator.gif
    This is a case where the electronics are pretty
    much a no-brainer but the task to be mounted and
    solved is getting the heat out. Average voltage drop
    in one of these regulators is 2.2 volts. So if you're
    dragging 30A from a really husky alternator, the
    R/R needs to get rid of 66W of heat.
    This is where attention is paid to the diodes and
    SCRs to use beefy devices with low thermal resistances
    and then mount them in an enclosure suited for conducting
    that much heat out of the box.  Problems with longevity
    of the PM R/R have roots more in cooling than in the
    absolute ratings of the components.
    For this design, I might even consider putting the
    hot parts on a finned heat sink and blowing air through
    the assembly. There's a wealth of 12V DC brushless
    fans out there to consider. I think I'd also add
    some form of temperature sensing to at least light
    a warning light and allow the pilot to consider a
    temporary load reduction.
    Just some food for thought. As soon as the support
    tools and materials for our hardwood floor project
    are out of the garage, I'll get started on the alternator
    drive stand . . . should be able to run some experimental
    regulator/alternator combinations on the bench this fall.
		Hoffmann.RS(at)T-Online.d Guest
				 Posted: Sun Aug 19, 2007 12:31 pm    Post subject: Rotax Voltage Regulator |
				Rotax rectifier / regulators (and the other  motorcycle types too) are not unproblematic. As Gilles found out by direct  experiment at nominal power the maximum temperature for the 912 / 914 series R/R  is minus 59° Celsius:<?xml:namespace prefix = o ns =  "urn:schemas-microsoft-com:office:office" />
 http://contrails.free.fr/elec_ducati.php
 This is somewhere in the vicinity of the liquid  CO2, please forgive me that I cannot transfer it to Fahrenheit units by heart  ( .
 I used a standard 3” vent from a computer power  unit mounted upon the cooling fins to make the system reliable, as Bob mentioned  too. Nevertheless the power output of the 2 phase Rotax alternator is marginal.
 A friend experienced a trip of the main circuit  breaker when operating the flaps at idle. Imagine what would have happened with  an electrical dependent 914 engine. His Dynon and his GPS went black too (which  is not an issue at the home airport). I am aware that he might beef up his 7Ah  battery a little bit, too (
 Increased use of glass panel instruments with  reasonable brightness, strobes etc. would ask for a state-of-the-art generator  system for the future. It is not very elegant to use a reduction gear and then  mount a generator driven by a belt from the prop axis to increase rpms again. It  is more elegant to mount a second generator the crankshaft itself rotating at  some 5000rpm at the back of the 912/914, which has been done:
 http://contrails.free.fr/elec_second_alternateur.php
 If You can live with one sole generator  providing sufficient power, the standard Rotax system should be modified.
 With the existing standard 2phase coil system I  can imagine that a more modern regulator could work not at the frequency  determined by engine rotation, but at a higher frequency as a real switching  regulator with a corresponding higher efficiency; maybe some inductivity would  have to be added.
 I would however prefer another way of solving  the problem. As the rpm is high enough, why not integrate a common 3phase  generator into the original site of the Rotax coils? One wound have to redesign  the (presumably 9) stator coils for the given dimensions and add a rotor with  coil. Add a standard regulator and You are done: greater power mainly because of  better efficiency, no high frequency switching problems, standard technology and  reliability, no belt to break, no hump in streamlined cowlings… Would be just a  standard generator put into the Rotax.
 By the way: You could even get rid of any  sliprings without any electric change at all. Honda has done that on their  CB500f motorcycles even some years ago:
 http://www.autoschrauber.de/content/000058/image/limakomplett.jpg
 The only disadvantage is the introduction of an  air gap. When reliability is an issue, that could be a good trade-off for  aircraft use anyway: almost no moving parts J.
 As Bob already stated, it would be an excellent  DIY – project - not without future potential.
 Richard
