rleffler
Posted: Sun Aug 19, 2007 1:54 pm Post subject: Blue Plastic removal |
I started out removing strips of the blue protective plastic to allow for dimpling and riveting. I’ve had several people comment that they had some corrosion issues focused under the edges of the blue plastic. The most recent was from the technical counselor that was just out for my first counselor visit.
So I guess the debate would be which symptom would be worse after 2-3 year build period, scratches or minor corrosion. Since all of these reports have been second hand, I’m looking for feedback from anyone that had any corrosion after the removed the blue plastic at the end of the build.
Any strong opinions with either option? Did anyone else find corrosion under the blue plastic when removed?
#40684
_________________ Bob Leffler
N410BL - Phase I
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Sun Aug 19, 2007 2:43 pm Post subject: Re: Blue Plastic removal |
Can not speak to the corrosion issue. I am stripping the blue plastic from the empanage with was finished 2 years ago and it is coming off in small hard to remove pieces.
I stripped the rest of the airplane as it was built.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
ron.mcgann(at)baesystems. Guest
Posted: Sun Aug 19, 2007 3:06 pm Post subject: Blue Plastic removal |
I left the vinyl on the skins in the shed extremes of heat/cold,
dry/damp for 3+ years. Corrosion was evident, but limited to only very
tiny areas at the vinyl edges - not worth a second thought. The vinyl
had hardened with age and was a little more difficult to remove, but I
have heard that slightly heating the vinyl with a heat gun allows it to
come off more easily
Ron
-187 finishing
speckter(at)comcast.net Guest
Posted: Sun Aug 19, 2007 3:36 pm Post subject: Blue Plastic removal |
From my experience with several builds, the bigger issue is the difficulty of removing the plastic after it has been stored for several years. In one extreme case I had to sand off the plastic with a power sander and z-strip paint remover in order to get it off. It is true that a heat gun helps, but the longer it is on and the more it is subjected to sunlight, even through windows, the tougher it is to remove. My solution to the scratch issue is to wrap the part in bubble wrap after it is completed. That protects against scratches and small blows.
Gary
40274
Wiring OP Tech panel
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Sunday, August 19, 2007 4:53 PM
To: rv10-list(at)matronics.com; rv-list(at)matronics.com
Subject: Blue Plastic removal
#40684 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
cehoffman(at)bellsouth.ne Guest
Posted: Sun Aug 19, 2007 4:13 pm Post subject: Blue Plastic removal |
I have had more corrosion problems from perspiration dripping on the aluminum than from any blue plastic that stayed on to protect the skin.
Cal Hoffman
40119 (Instrument Panel)
rvbuilder(at)sausen.net Guest
Posted: Sun Aug 19, 2007 5:05 pm Post subject: Blue Plastic removal |
I’ll echo what Gary said, it can get to be a bear to get the stuff off after a while. I also used to do the strips but just didn’t see the point anymore. Besides, you are going to scratch the hell out of it when you go to paint it anyway. And any minor filliform or other corrosion will also be removed when you go to sand it. Better to let it breath in my opinion.
Michael
#40684 [quote] ; - The RV10-List Email Forarch & Download, 7-Day Browse, Chat, FAQ,[/b]_; --> http://www.matronics.bsp; - NEW MATRONICS WEB FO; http://forums.matronics.com</================== [b]
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sun Aug 19, 2007 7:14 pm Post subject: Blue Plastic removal |
Howdy, You may find the vinyl coating difficult to remove after a 2-3 year period. Here is an excerpt from "Materials used in RV Airframes (Section 5) Part 1" located in the construction section of Van's website.
5M VINYL COATING
Many of the alclad parts are supplied with a thin (usually blue) vinyl coating to prevent scratching during the
manufacturing of the parts. The vinyl may be left on during drilling but should be removed for dimpling, priming and
final installation. It is possible to remove strips of vinyl along rivet lines with a soldering iron. Carefully round and
smooth the tip of the iron so it won’t scratch the aluminum.
The adhesive on the vinyl strengthens with age, so if the coating is left on for more than a few weeks, it may become very difficult to remove.
Corrosion has been found under the vinyl in some instances. If vinyl covered parts
must be stored for long periods, remove the vinyl first.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
rene(at)felker.com Guest
Posted: Sun Aug 19, 2007 8:40 pm Post subject: Blue Plastic removal |
I just removed mine from the completed fuselage. The plastic has been on for 1.5 to 2.5 years. No corrosion and not hard to remove.
Rene'
40322
Fisnish…….paint
801-721-6080
