Flap switch install?
tdawson-townsend(at)auror
PostPosted: Sun Aug 19, 2007 5:31 pm    Post subject: Flap switch install? Reply with quote
Where have folks installed the micro-switch on the flap system for use with an AOA Sport? I checked the website, but couldn’t find anything specific on the preferred install location.
Pictures appreciated, if you can send them directly to my email address. (us digest folks don’t get attachments)
TDT
Tim Dawson-Townsend
Aurora Flight Sciences
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
GenGrumpy(at)aol.com
PostPosted: Sun Aug 19, 2007 5:36 pm    Post subject: Flap switch install? Reply with quote
i took the easy way and did not install the switch.
Just set mine for flaps up stall indication.
Works like a champ with the docile stall characteristics of the bird.
grumpy
N184JM 60+ hours and now into painting it
In a message dated 8/19/2007 8:33:13 PM Central Standard Time, tdawson-townsend(at)aurora.aero writes:
TDT
Tim Dawson-Townsend
ScooterF15
PostPosted: Thu Aug 23, 2007 3:35 pm    Post subject: Flap switch install? Reply with quote
Here's where I put mine (pictures attached). Note, one picture has a mirror in it to show switch actuation on the bottom of the flap actuator.
For guys on the digest, go to http://forums.matronics.com and search for this thread. The pictures are available there.
-Jim
40134
In a message dated 8/19/2007 9:33:13 P.M. Eastern Daylight Time, tdawson-townsend(at)aurora.aero writes:
TDT
Tim Dawson-Townsend
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
 Filesize:  43.97 KB
 Viewed:  525 Time(s)
 Filesize:  29.37 KB
 Viewed:  540 Time(s)
 Filesize:  38.17 KB
 Viewed:  532 Time(s)
n223rv(at)wolflakeairport
PostPosted: Mon Aug 27, 2007 5:32 pm    Post subject: Flap switch install? Reply with quote
Here is what I did, hopefully you can see it in the picture. I riveted a tab on the end of the flap horn (left side of picture) and it hits the switch on the right side of the picture.
-Mike Kraus
 Filesize:  47.65 KB
 Viewed:  524 Time(s)
