Deems Davis
Posted: Thu Aug 23, 2007 12:52 pm Post subject: Control stick freq flip/flop |
I'm debating whether or not to connect the Freq Flip-Flop switch to my
control grips. My initial thought is to NOT connect it, I have the
capability of changing freq's either through my EFIS or direct through
the radio/s and adding yet another option increases complexity and
failure points. However in the back of my mind I recall a post from
someone how either loved or hated this feature on their stick, anybody
out there?
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Tim Olson
Posted: Thu Aug 23, 2007 1:11 pm Post subject: Control stick freq flip/flop |
I know I like it....
One hand on the stick flying, one on the EFIS, choosing the freq from
the list and hitting SEND TO COM1. Then I just flick the switch
on the stick and I'm active...never had to reach for the radio.
I don't use it all the time, but unless you have another
function you want to use, it's a good one. I have the switch
set to push up flip/flop COM1, and down flip/flop COM2.
out there?
Deems Davis # 406
Posted: Thu Aug 23, 2007 1:37 pm Post subject: Control stick freq flip/flop |
I have decided to include it on both pilot & pax control sticks (plus a
full pax deactivation switch). I debated and debated and finally decided
to include it on my stick. I figure removing the feature it is easier
than deciding later that I want to add it. My thinking was when I am
flying ahead of my plane either my G900X will have the next comm loaded
or I will have entered it in the stand by and rather than reach up again
I will just hit the switch. Why not...
Robin
GenGrumpy(at)aol.com Guest
Posted: Thu Aug 23, 2007 5:44 pm Post subject: Control stick freq flip/flop |
I, too, have the flip flop on both stick grips.
I would not like to be without it. Like Tim - very handy.
grumpy
N184JM
In a message dated 8/23/2007 4:12:51 PM Central Standard Time, Tim(at)MyRV10.com writes:
Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Deems Davis wrote:
Quote: | --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
out there?
Deems Davis # 406
scottmschmidt(at)yahoo.co Guest
Posted: Fri Aug 24, 2007 9:56 am Post subject: Control stick freq flip/flop |
Sounds like I will be the first to be neutral on this issue.
I have the com and nav flip/flop on my stick and honestly I don't use it much. That doesn't mean I wouldn't put it in.
For me, the time when I am changing frequency the most is either in very busy class B airspace or IFR. During those times you are changing at the request of ATC, you typically don't know what frequency your switching to, and your hand is already on the panel anyway rotating the knob.
This may sound crazy, but I wish I was able to wire the volume for my xm radio into the stick. I find myself adjusting that depending on if I like the tunes that are on.
Scott Schmidt
scottmschmidt(at)yahoo.com
