leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Oct 28, 2007 5:55 pm Post subject: lighting minihelic |
Has anyone got any good ideas for lighting a minihelic as used as an LRI?
Dan Dempsey
plans building 601XL
_________________ Scratch building XL with Corvair Engine |
georgerace
Posted: Mon Oct 29, 2007 7:04 am Post subject: lighting minihelic |
Hi Dan:
You can do a very nice job of lighting an instrument with a small red LED. The small "grain of wheat" size works well.
Remove the instrument from its case.
Remove the glass lens from the case.
Drill a small hole the size of the small LED from the outside of the case to where the edge of the glass fits into the case.
Install and epoxy the led into the hole so that it just barely touches the glass when installed.
Hook the LED, with a proper series resistor to a 12 volt source. Do not hook it to the panel dimmer control.
Although it cannot be successfully dimmed, it will cast a nice red glow on the face of the instrument. The glass acts as a conductor of the light and provides nice even illumination.
George
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
paulrod36(at)msn.com Guest
Posted: Mon Oct 29, 2007 12:18 pm Post subject: lighting minihelic |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> There's also another way: Some years ago a masked outlaw broke into my Skyhawk. He took a sheet of 1/8th inch plexiglas and duplicated the instrument panel cover, making cutouts for each instrument and the pegs on the back of the cover. This arch fiend then proceeded to run wires and wheat-grain bulbs, in parallel,two for each instrument (roughly 10 and 2 oclock) and poked the bulbs through appropriately-sized holes in the plastic. This evil monster then inserted the package under the stock panel cover, and ran the wires to the existing rheostat. After performing his hideous deed, he skulked away in the dark of the night and I never saw him again. I am still incensed that someone would to this to a perfectly good certified aircraft. I will never forgive him for bathing each instrument in a controllable glow. Now that I think about it, he may have done the same dastardly deed on other unsuspecting aircraft, but in red plastic. Someday I may report that vandal.
Paul Rodriguez
601XL Corvair
leinad
Posted: Mon Oct 29, 2007 3:37 pm Post subject: Re: lighting minihelic |
George,
You're idea sounds good. In fact I thought of doing that but I'm afraid that the instrument case may be a pressure vessel of sorts, and was afraid to compromise the integrity of the case. I'd love to hear from someone that has actually used this method on a Dwyer Minihelic without ill effect.
Dan
[quote="georgerace"]Hi Dan:
George
leinad
Posted: Mon Oct 29, 2007 3:46 pm Post subject: Re: lighting minihelic |
Paul,
Thanks for the reply, and normally that'd be the perfect method, but the minihelic installs like a lot of auto instrument gages. It is held on by having the lens larger than the case, and mounted through a hole the size of the case, then clamped from the back. To use the "vandals" method I'd have to find a way to mount the gage behind the panel, without the standard instrument mounting screws. I'm starting to sound like "there's hole in the bucket dear Ida".. Still worth some thought though.
Thanks again.
Dan Dempsey
[quote="paulrod36(at)msn.com"]<xml><xml><endif> There's also another way: Some years ago a masked outlaw broke into my Skyhawk. He took a sheet of 1/8th inch plexiglas and duplicated the instrument panel cover, making cutouts for each instrument and the pegs on the back of the cover. This arch fiend then proceeded to run wires and wheat-grain bulbs, in parallel,two for each instrument (roughly 10 and 2 oclock) and poked the bulbs through appropriately-sized holes in the plastic. This evil monster then inserted the package under the stock panel cover, and ran the wires to the existing rheostat. After performing his hideous deed, he skulked away in the dark of the night and I never saw him again. I am still incensed that someone would to this to a perfectly good certified aircraft. I will never forgive him for bathing each instrument in a controllable glow. Now that I think about it, he may have done the same dastardly deed on other unsuspecting aircraft, but in red plastic. Someday I may report that vandal.
Paul Rodriguez
601XL Corvair
dbortol
Posted: Tue Oct 30, 2007 6:22 am Post subject: lighting minihelic |
Dan,
The case does connect directly to one of the pressure ports.
The black ring around the outer edge of the face is painted on. If you look at it from the side, you can see that clear plastic lies below the thin black layer. I was thinking to make a small hole in the flange of the case, radially outboard as far as possible, to mount a small LED which would shine into the back side of the clear layer. I need to take the face off my gauge again to make sure that it wouldn't affect the seal between the face and case.
Dino Bortolin
On 10/29/07, leinad <leinad(at)hughes.net (leinad(at)hughes.net)> wrote:[quote] --> Zenith-List message posted by: "leinad" <leinad(at)hughes.net (leinad(at)hughes.net)>
George,
Dan
George
http://forums.matronics.com/viewtopic.php?p=142625#142625 [quote][b]
Trainnut01(at)aol.com Guest
Posted: Tue Oct 30, 2007 7:19 am Post subject: lighting minihelic |
Dan
Why don't you just put a post light on it. They are not terribly expensive and they work great. I used them on some of the lights in my RV and they worked so good I unhooked the internal lights I already had on some of my instruments and put post lights on them too.
Carroll Jernigan
do not archive.
See w [quote][b]
leinad
Posted: Tue Oct 30, 2007 3:37 pm Post subject: Re: lighting minihelic |
[quote="Trainnut01(at)aol.com"]Dan
Carroll Jernigan
do not archive.
See w
Carrol,
Thanks. I've heard about post lights but never seen one. I'll look into it.
It might be the perfect solution. I have one other gage (EGT/CHT) that isn't presently lit, but the other ideas that have been talked about would work good on that one.
Dan
planelists(at)optonline.n Guest
Posted: Tue Oct 30, 2007 4:28 pm Post subject: lighting minihelic |
| Quote: | Thanks. I've heard about post lights but never seen one. I'll look into
it.
Dan
Here is one:
http://www.engalt.com/aviation.htm
George
