nico(at)cybersuperstore.c Guest
Posted: Tue Aug 28, 2007 5:43 am Post subject: Weird 747 shadow |
Look at google earth at this location: 26 02 03 S, 28 14 04 E
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
John Vormbaum
Joined: 21 Aug 2006 Posts: 273 Location: SF Bay Area, CA
Posted: Tue Aug 28, 2007 9:14 am Post subject: Weird 747 shadow |
Nico,
All I see there is a location between Pretoria and Johannesburg, of a
house with a pool.....no shadow on my version.
/J
nico css wrote:
__________ NOD32 2488 (20070828) Information __________
bowing74(at)earthlink.net Guest
Posted: Tue Aug 28, 2007 9:22 am Post subject: Weird 747 shadow |
I see the shadow you're talking about but haven't an explanation for it. It
is a 747-400 in a left turn.
bilbo
steve2(at)sover.net Guest
Posted: Tue Aug 28, 2007 11:14 am Post subject: Weird 747 shadow |
I have a 'possible' explanation for this. The Google Earth imagery are not
conventional photos, but 'orthophotos'. That is the image is composed of
zillions of photographs that are mosaicked together, and processed to
correct them for tip and tilt of the camera, and to correct the scale of
images versus the variations in height of the land. Lots of other stuff gets
done to the images.....
I'm actually processing an orthophoto right now at work. (I'm hard at work,
honest.)
The ortho images have a lot of blending and processing done to them to have
them look any good across seams, and to correct for vignetting and uneven
tone across them. Its quite a trick to get all these images to look any good
all stuck together at once.
It is possible that the 'weirdness' is due to a computer algorithm doing its
best to make sense of this little image patch, and lighten up a dark area,
and darken up a bright area.
Or it's something else.
Steve
Posted: Tue Aug 28, 2007 12:56 pm Post subject: Weird 747 shadow |
John,
Did you copy and paste the coordinates into google earth? It should be on
the edge of a suburban neighborhood.
Nico
Posted: Tue Aug 28, 2007 1:14 pm Post subject: Weird 747 shadow |
Thanks, Steve. That makes the most sense.
Nico
John Vormbaum
Posted: Tue Aug 28, 2007 1:40 pm Post subject: Weird 747 shadow |
That time it worked....and that is quite the funky shadow/airplane.
nico css wrote:
John,
Nico
andrew.bridget(at)telus.n Guest
Posted: Tue Aug 28, 2007 4:05 pm Post subject: Weird 747 shadow |
Yes, very interesting - note that the ghosted image is above the 'clear' 747 - I wonder if it has something to do with a second photo taken immediately after the first; the 747 having moved on since the first? I'm sure there's a better explanation...
God bless,
Andrew
Posted: Tue Aug 28, 2007 4:23 pm Post subject: Weird 747 shadow |
Hi Andrew.
I don’t think so, because the 747 would have to have drifted south without any forward movement. The shadows of the surrounding structures indicate that it’s early morning, so in that respect the blue shadow is in the right place. What is a bit off, I would say, is that the shadow indicates that the sun is slightly south of the 747, which is impossible seeing that Johannesburg is 26 deg south and the sun never gets further south than 23.5 deg. However, if the shadow was moved due to manipulation of the satellite photographs, then it might not show where it actually was.
Steve gave an excellent explanation: satellite photos are not regular photos but orthophotos, which are programmatically manipulated to make the individual satellite images fit seamlessly in one image, and perhaps some shift could have changed the color of the shadow. Steve I apologize if my paraphrasing what you said has lost the message.
Who knows, but it is very interesting.
Nico
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of andrew.bridget(at)telus.net
Sent: Tuesday, August 28, 2007 5:05 PM
Subject: Re: Weird 747 shadow
| Quote: | Look at google earth at this location: 26 02 03 S, 28 14 04 E
God bless,
Andrew
| Quote: | | http://www.matronics.com/Navigator?Commander-List | 01234
Posted: Tue Aug 28, 2007 4:59 pm Post subject: Weird 747 shadow |
Hi, yes, Nico,I think Steve is likely right; I only read his post after I responded. Talk about opening my yap before I have all the info
Found some other aircraft with ghosted shadows. No I didn't scan Google Earth ... well I did look at O'Hare to see if there were any on approach/climbout, and at Vancouver, Toronto, Calgary, and ... but then I gave up and cheated by looking at http://www.gearthhacks.com/dlcat24/Aircraft-in-flight.htm
Steve, given this, is it not possible that two photos are taken and then overlaid to give the 3D effect when one tilts the earth to a more horizontal plane? (pun unintended) This would explain the aircraft "moving on". In each of the ghosted shadows the ghost aircraft appears to be on (or slightly higher) than the clear aircraft. However, on a slower aircraft (like the helicopter, or aircraft on finals) there isn't any ghosting.This would add to the theory that the aircraft has moved on - only fast aircraft appear to be ghosted.
Blessings
Andrew
Posted: Wed Aug 29, 2007 2:45 am Post subject: Weird 747 shadow |
Hi Andrew,
It gets a little complicated......
The 3D effect is used by many companies to create the terrain model used by so many applications. It could be flight simulators, or GPS units with ground proximity in them.... What Google is doing is using that model to 'drape' their imagery over it to give you that 3D effect.
I'll take a look at those examples when I am back at a fast modem, but I have another 'possible' explanation for what you are seeing.
In order for an orthophoto to be scaled properly the original photo has to stretched and shrunk to fit the terrain. Think of the left side of a photo as having a mountain, and the right side with a valley. The two sides of one photo will have different scales...... This effect is further complicated by the fact that only in the center of the image is the camera looking directly down, vertically. For most of the image, the subject is at more and more of an angle off center.
This 'looking off center' is not an insolvable problem as long as the object is draped onto the terrain model. But any object that stands proud from the terrain model is going to be put in the wrong place. The higher something is, and the further off perpendicular from under the camera, the more horizontal error will be introduced when the object is forced down to the terrain model.
So tall buildings will appear misplaced. Aircraft could appear a great distance from where they should have been on the earth directly beneath them.....
The simple answer is; every image pixel needs a proper elevation in order to be placed accurately in horizontal.
As for multiple images causing ortho-weirdness, it does all the time. Things like a baseball field with way too many players and a bunch of other errors, some of them quite funny......
David Owens, on this list, I'm sure takes quite a lot of imagery destined for ortho photos also, with their Colemill 500A.....
Steve
10.05 KB |
357 Time(s) |
bertberry1(at)aol.com Guest
Posted: Wed Aug 29, 2007 5:14 am Post subject: Weird 747 shadow |
For what its worth, I think it has to do with shutter speed. Slower shutter speed which allows better detail. In addition, a lot of these are not sat photos but are aerial photos that are piece milled in.
Bert
Sent via BlackBerry by AT&T
dowens(at)aerialviewpoint Guest
Posted: Wed Aug 29, 2007 6:32 am Post subject: Weird 747 shadow |
Actually, when you use some of the GEO software such as Leica Suite, and Imagine, some of the features you can choose to "merge" the images seamlessly allow you to "feather" the images, which makes the image progressively trsnsparent to the extent of the image... to appear more seamless between frames, as well as auto dodging, which will change the actual gamut of each image to match more or less creating another aspect of "seamless" as the eye can see... color and density assuming the images were captured at or near the same sun angle, weather etc. As for the "ghost" shadow, I think it was feathered below the image that was overlayed after, like you guys said... BAWK!
David Owens
Aerial Viewpoint
N14AV
AC-500A-Colemill
