Yak 55M Aileron Bearings
jsnafziger(at)yahoo.com
PostPosted: Wed Aug 29, 2007 11:55 am    Post subject: Yak 55M Aileron Bearings Reply with quote
During preflight I noticed the outboard aileron on my Yak55M wiggled
fore/aft. I check it regularly, so this is something new. The left
aileron is solid. The aileron bracket to the wing is tight, so the
movement is within the aileron hinge or bearing.
Is this something that common with the Yaks? I remember seeing an
email about that before, but searching the archives, I couldn't find.
John
windsorsedge(at)ozemail.c
PostPosted: Wed Aug 29, 2007 3:45 pm    Post subject: Yak 55M Aileron Bearings Reply with quote
John had the same problem on my 52 easy to replace in no time. Replacement
bearings from local bearing shop
Tim & Jessie Windsor
Windsors Edge Vineyard
Windsors Edge Cottages
Top Red War Birds
1039 McDonalds Rd POKOLBIN NSW 2320
T/F: 02 4998 7737
E: windsorsedge(at)ozemail.com.au
viperdoc(at)mindspring.co
PostPosted: Wed Aug 29, 2007 5:44 pm    Post subject: Yak 55M Aileron Bearings Reply with quote
John,
If you can't find them, Rob Kent has them as does Doug Sapp and Gill Hayes.
Doc
dsavarese(at)elmore.rr.co
PostPosted: Wed Aug 29, 2007 6:03 pm    Post subject: Yak 55M Aileron Bearings Reply with quote
Attention to all the exposed bearings in the Yak is very important. That
is, they should be cleaned and lubricated regularly. On the 52, the inboard
aileron bearing is always the most difficult to clean and lubricate. But it
must be done regularly. Bearings that are exposed to the elements, like the
outboard aileron bearing you mentioned are particularly prone to picking up
grit and grime. This of course destroys the bearings. I'm not sure about
the 55M outboard aileron bearing, but the outboard aileron bearing on the 52
is unique and expensive compared to the very common 19mm OD x 6 mm (ID) x 6
mm (W) self aligning bearings.
Dennis
jorgen.nielsen(at)mweb.co
PostPosted: Thu Aug 30, 2007 9:58 am    Post subject: Yak 55M Aileron Bearings Reply with quote
I have had to replace my bearings. They developed play - can test it on the
tips, by holding the aileron top and bottom at the leading edge and trying
to move it up and down.
Are there any aftermarket / western replacements for the originals?
TigerAirshows
PostPosted: Tue May 01, 2018 5:51 am    Post subject: Re: Yak 55M Aileron Bearings Reply with quote
Yep, found some play in my 55M aileron. I changed out my bushings 10 years ago but at 500hrs the play has resurfaced. Anyone have the press in bushings for the Yak 55M aileron hinge?
Thanks.
-Mark
www.tigerairshows.com
Mark Sorenson-
jbsoar(at)gmail.com
PostPosted: Tue May 01, 2018 6:11 am    Post subject: Yak 55M Aileron Bearings Reply with quote
I'd take a set as well!Thank you!
John B
On Tue, May 1, 2018 at 8:51 AM, TigerAirshows <captainsorenson(at)hotmail.com (captainsorenson(at)hotmail.com)> wrote:
--> Yak-List message posted by: "TigerAirshows" <captainsorenson(at)hotmail.com (captainsorenson(at)hotmail.com)>
Thanks.
-Mark
Mark Sorenson-
http://forums.matronics.com/viewtopic.php?p=479746#479746
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
WIKI -
