		thilo.kind(at)gmx.net Guest
				 Posted: Thu Sep 06, 2007 9:29 am    Post subject: Was Nothing new then now propeller  twist |
				Hi there,
 I'm flying a Zodiac 601 HDS with Rotax 912 with the water rad unerneath the cowling (original Rotax rad). Depending on the OAT the water temps start to climb to 220 F over a period of 10 minutes or so. During climb out I typically see 210 F. In cruise, the water temps drop to 140 F. CHT temperature on the other hand does stay pretty stable at around 100 F (it's a bit higher, since the sensor is not properly calibrated).
 Also, a few weeks ago I had an incident with the Rotax: one of the cooling hoses from the rad to the pump burst open and I lost all coolant fluid in flight. Luckily, I was right over the airpoirt and down at the ground within 4 minutes. During that time, the CHT temps didn't go up despite lack of cooling fluid. Also, the water pump was not damaged due to lack of fluid. Pretty good engine....
 Thilo
 -------- Original-Nachricht --------
  	  | Quote: | 	 		   Datum: Thu, 6 Sep 2007 10:07:10 +0100
  Von: "R.C.Harrison" <ptag.dev(at)tiscali.co.uk>
  An: rotaxengines-list(at)matronics.com
  Betreff: RE: Re: Was Nothing new then now propeller twist
  Hi!Roger
  No. Not that I could tell. Maximum 5 minutes and the coolant is too hot
  to make a dash for it! I'm resigned to accept that at present, since
  when flying it's fine. I get words of advice that after 10 to 50 hours
  it runs cooler anyway.
  I tried the half choke setting in flight yesterday and it made no
  difference to coolant temps. I thought running richer would have had a
  dramatic effect since the guys with a mixture facility can control their
  burn really well.
  Bob Harrison. G-PTAG
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		hgmckay
				 Posted: Thu Sep 06, 2007 11:07 am    Post subject: Was Nothing new then now propeller  twist |
				Thilo:
 What caused the radiator hose to burst? Was is a defective hose, loose
 clamp, or what?
 Hugh McKay
