XDP4K - Getting a "300 Error" when trying to access CNW Edit
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> XDP4000X-List
randyman(at)gmail.com
PostPosted: Wed Aug 29, 2007 11:29 pm    Post subject: XDP4K - Getting a "300 Error" when trying to access CNW Edit Reply with quote
Hello,
I needed to re-configure/re-align my system, so I hooked up my laptop to my XDP-4000x. It has been over 3 years since I had to do this. It initially worked fine - I just did a few quick tweaks to the X-Over with the DSC software. Then, I went back last week, and I was ready to fine tune my system with my RTA ready to go. Now, when I try to open the DSC "CNW" editor (for X-Over and Delays), I get some kind of "300" error on the laptop, and the DSC application closes out when I click "OK" on the pop-up box. I can not seem to access any of the XDP's CNW features via the Laptop. The XDP's CNW Preset Memory is still entact (or else I'd have a paperweight on my hands - arrrrgh!).
I can access the EQ just fine (adjusting and saving/uploading the EQ works perfectly via the DSC software)! What is going on??? I also tried another laptop, and I get the same error (only for CNW)? I also tried to completely power down the C90/XDP (Removed +12v for a few minutes), and I still experienced the same error on both laptops...
Could this be a Null-Modem Cable issue? I kind of doubt it as I doubt the CNW editor uses different Serial wires than the EQ editor uses, ya know? And the fact that this same thing happens on 2 Laptops is odd.
I'd hate to say it, but this might be the final straw for my dear C90/XDP-4000x. I am inches away from doing a Car-PC (Waiting for the new Panda CT650 LCD Monitor to come out this summer), but I'd really like to get my XDP's x-over and delays tweaked NOW for my new installation Sad . I also wanted to use the XDP4K in my other ride (4-Runner 4x4) once I get a Car-PC in this ride (Tacoma 4x4). That dream may soon be put to rest...
Thanks for any help from a stuck XDP user.
PS - I was also the guy having iPod issues with my C90/XDP. I junked the crappy PAC "Aux-In Unilink Adaptor" that was locking up my system in favor of a Sony XA-300. I still get some weird issues with the motorized face changing angles on its own, but I no longer have the "Freezing" issue on power-up (thank GOD!!! That was very annoying).
Rock and/or Roll
Randy V.
Houston, TX
Audio-Dude/Musician/Crazy Guy
- The Matronics XDP4000X-List Email Forum -
http://www.matronics.com/Navigator?XDP4000X-List
PostPosted: Thu Aug 30, 2007 10:54 am    Post subject: XDP4K - Getting a "300 Error" when trying to access CNW Edit Reply with quote
Thanks for the suggestions, Matt. One of the laptops was using a USB-to-Serial adaptor (Running XP), and one of the laptops was using a "real" Serial Port (Running Win98). Tried Compatibility Mode on the XP Machine, no difference. The older laptop with the Serial Port is the same Laptop I used to setup my XDP system 3-4 years ago, and I have not used that particular laptop for anything else since then (it was a $100 P.O.S. laptop I bought just for programming the XDP!).
The funny thing is the XP Laptop with the USB-to-Serial adaptor worked initially (I was able to edit my X-Over the first time I hooked it up). I didn't get any errors until the second time I went to interface the Laptop! Then neither Laptop woud work...
Do you think there is a small chance my Null Modem Cable might be bad? Maybe just passing enough data to allow EQ edits, but not CNW edits w/o errors? Do you still have a link to who sells the Serial Null-Modem cables compatible with the XDP? Any other suggestions?
Thanks again
Randy V.
Houston, TX
bobbybraun
PostPosted: Thu Aug 30, 2007 11:06 am    Post subject: Re: XDP4K - Getting a Reply with quote
It seems you've ruled the computer out as being the culprit, after using two very different systems while making the connection.
I would start with swapping out the null modem cable, hopefully the problem is as simple (and as cheap) as that. You might also want to try a different version of the Sony DSC software.
Otherwise I can see no other solution than sending the 4000x in for repair... Best of luck!
Sony ES CDX-C90, XDP-4000X, XM-2000R, Phoenix Gold M44, MS2250, Infinity Beta 8-5-1
PostPosted: Thu Aug 30, 2007 12:54 pm    Post subject: XDP4K - Getting a "300 Error" when trying to access CNW Edit Reply with quote
Thanks for the inspiration/hope, Bobby Smile
Do you know of any places that sell Null Modem cables off the top of your head? I'll do some searching in a moment. Was there anything specific (besides the "Null Modem" wiring aspect) that I need to verify for XDP Useage?
Thanks again
Randy V
On 8/30/07, bobbybraun <bobbybraun(at)comcast.net (bobbybraun(at)comcast.net)> wrote:
--> XDP4000X-List message posted by: "bobbybraun" < bobbybraun(at)comcast.net (bobbybraun(at)comcast.net)>
Randy V.
Houston, TX
Audio-Dude/Musician/Crazy Guy [quote][b]
bobbybraun
PostPosted: Sun Sep 02, 2007 5:02 am    Post subject: Re: XDP4K - Getting a Reply with quote
Matt has links to a couple on his site at www.matronics.com/xdp4000x
Here are the shortcuts for your convenience:
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=1&Product_Id=16633
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=1&Product_Id=16637
Hope you get it working! Best of luck!
PostPosted: Tue Sep 04, 2007 6:15 pm    Post subject: XDP4K - Getting a "300 Error" when trying to access CNW Edit Reply with quote
Thanks Roland. I recall seeing some discrepancy in Null-Modem Wiring as I searched online (flipping 1 pair or 2 pairs of terminations), so I just wanted to be sure I don't make this issue worse by using the wrong cable.
I finally found Matt's XDP Page that listed the Belkin model cable, and I ordered one from Provantage for like $8 shipped (F-F DB9 10' Null Modem). I'm crossing my fingers, but things like this usually aren't such an easy fix for me...
Beyond that, I might try swapping Unilink cables for the heck of it (but I doubt that would help my problem here).
A CarPC and the Panda Monitor might be happening sooner than I thought Smile
I'll let you know what happens
Randy Visentine
On 9/4/07, Roland M <mdx400(at)hotmail.com (mdx400(at)hotmail.com)> wrote: [quote]--> XDP4000X-List message posted by: "Roland M" <mdx400(at)hotmail.com (mdx400(at)hotmail.com)>
From: "Randy Visentine" <randyman(at)gmail.com (randyman(at)gmail.com)>
Reply-To: xdp4000x-list(at)matronics.com (xdp4000x-list(at)matronics.com)
Subject: Re: Re: XDP4K - Getting a "300 Error" when trying
to access CNW Edit
Date: Thu, 30 Aug 2007 15:54:16 -0500
Useage?
Nah a null modem cable is a null modem cable. You just need the right ends
M/F or whatever the cable has to be, and the right size (can be either 9 pin
or 25 pin; 25 pin ports only really use 9 pins so I have no clue why they
were ever used on PCs). You can probably get one from Monoprice
http://www.monoprice.com .
Roland M.
A place for moms to take a break!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> XDP4000X-List All times are GMT - 8 Hours
