jconnell(at)fmwildblue.co Guest
Posted: Thu Aug 30, 2007 7:26 pm Post subject: Questions on O-320-D2A Sump Drains and a Slick Mag |
Hi,
My O-320 D2A has 3 sump drain plugs. Should I use any
particular plug to drain the oil? Are the three drain plugs
for the convenience of various aircraft types?
One more question:
I have a P-Mag and a Slick impulse mag on the O-320. I
can see where the P-lead goes on the Slick mag. I'm using a
toggle switch to control the magneto and am using the shield at
the switch end to complete the circuit. Is this the way to wire
it or will grounding both ends of the shield generate noise?
(My Rotax past isn't helpful here!)
Thanks guys,
Joe Connell
RV-9A N95JJ
Charles Heathco
Posted: Fri Aug 31, 2007 6:50 am Post subject: Questions on O-320-D2A Sump Drains and a Slick Mag |
Re grounding, ground at mag end only I was told, if both you will get noise Charlie H
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Fri Aug 31, 2007 11:55 am Post subject: Questions on O-320-D2A Sump Drains and a Slick Mag |
Joe,
Use whichever of the three sump drains that is most convenient for you.
On the wiring for the mag.If you are using the shield to complete the grounding circuit, it would not be grounded on the switch end. The shield is providing the second leg of the P lead grounding from the switch.
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
