Installing a 912
Float Flyr
PostPosted: Thu Aug 30, 2007 4:21 am    Post subject: Installing a 912 Reply with quote
I have a 912 arriving here tomorrow sometime... The earlier the better as
it's supposed to be a fantastic day for flying again.
I was wondering if anyone has pictures of their installation on a model II.
I have contacted John McB. and I expect to get the engine mount from him.
Now I have to worry about how to install the cowl.
Buckets of photos would be appreciated... The high speed is now working
let's put it to the test!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
hgmckay
PostPosted: Thu Aug 30, 2007 9:48 am    Post subject: Installing a 912 Reply with quote
Noel:
I have a few pictures of installing a 912 on my Allegro 2000. I will be glad
to copy them to you if you want to see them. Let me know.
Hugh McKay
Allegro 2000
912 UL
Float Flyr
PostPosted: Fri Aug 31, 2007 4:41 am    Post subject: Installing a 912 Reply with quote
Thanks Hugh:
You can either send them through the list or directly to noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca) if you think they arte a bit too big to send through the list.
I have been going through the installation manual but as they say a picture is worth a thousand words.
Noel
Time: 10:48:03 AM PST US
Subject: RE: RotaxEngines-List: Installing a 912
Noel:
I will be glad
Hugh McKay
Allegro 2000
912 UL
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
hgmckay
PostPosted: Fri Aug 31, 2007 3:40 pm    Post subject: Installing a 912 Reply with quote
Noel:
<![if !supportEmptyParas]> <![endif]>
I have about 17 photographs of my engine taken at various points during the assembly. Mounting my engine to the Allegro engine mount was very simple and the engine fit like a glove. I’m not sure what your engine mount looks like. I may be different than mine. Anyway, attached are a few (5) of the pictures in .jpg format. I’ll send five more in a separate email directly to your address. Then I will send the other seven. Hopfully this will not clog up your email. If for some reason the “List” strips the first 5 photos out, let me know and I’ll send them direct.
Do not archive.
Hugh
-----Original Message-----
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com]On Behalf Of Noel Loveys
Sent: Friday, August 31, 2007 8:41 AM
To: rotaxengines-list(at)matronics.com
Subject: RotaxEngines-List: Installing a 912
Thanks Hugh:
Noel
> From: "Hugh McKay III" <hgmckay(at)bellsouth.net>
> Subject: RE: Installing a 912
> Noel:
> I will be glad
> Hugh McKay
> Allegro 2000
> 912 UL
<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The RotaxEngines-List Email Forum - --> http://www.matronics.com/Navigator?RotaxEngines-List   - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>
 Filesize:  130.4 KB
 Viewed:  572 Time(s)
 Filesize:  127.16 KB
 Viewed:  585 Time(s)
 Filesize:  125.06 KB
 Viewed:  557 Time(s)
 Filesize:  127.03 KB
 Viewed:  579 Time(s)
 Filesize:  125 KB
 Viewed:  554 Time(s)
Float Flyr
PostPosted: Sat Sep 01, 2007 6:44 am    Post subject: Installing a 912 Reply with quote
Thanks Guys:
I have had several replies about pictures. I am getting the digest version of this list and all the pictures are stripped off. I have tried to find the whole posts on Matronics and haven't been able to find them.
I guess the best thing is just to send them direct to noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca) BTW Hugh I may have accidently deleted an incoming E-Mail from you.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
hgmckay
PostPosted: Sat Sep 01, 2007 7:54 am    Post subject: Installing a 912 Reply with quote
Noel:
I had the feeling that the photos I sent would be stripped. I will send my photos directly to you in three batches of 5, 5, and 7. I will also send the deleted email directly to you.
Hugh
Sent: Saturday, September 01, 2007 10:44 AM
Thanks Guys:
Noel
<![if !supportEmptyParas]> <![endif]> [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The RotaxEngines-List Email Forum - --> http://www.matronics.com/Navigator?RotaxEngines-List   - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
