inertial belt update
dlm46007(at)cox.net
PostPosted: Wed Feb 15, 2006 8:52 pm    Post subject: inertial belt update Reply with quote
Just an update on the inertial belts from AMSAFE. The belts sizings have
been finalized and four belts will be installed in an RV10 in TX in March.
My lid is prepared and another set will go into mine when I get to that
section.
part numbers of the restraints are as follows:
Front Seats: 4076-3-451-xxxx
Rear Seats: 4076-3-461-xxxx
Front Seats w/Extra lap Length: 4076-3-471-xxxx
the xxxx is the color code.
If you want to look at the airframe preparation go to www.inertialbetls.com
. The procedure shows the lid off the aircraft. If you want to install them
but already have fixed the lid in place then contact me as there is easy
change to the procedure that will minimize the mess of installing the hard
points externally.
LloydDR(at)wernerco.com
PostPosted: Thu Feb 16, 2006 6:16 am    Post subject: inertial belt update Reply with quote
The link should be http://www.inertialbelts.com/
In the original post the l and the t are reversed
Dan
40269
