Sbennett3(at)aol.com Guest
Posted: Mon Sep 03, 2007 2:36 pm Post subject: kitfox trim. |
I recently purchased a kitfox 4 1200 with a rotax 912. When we try to trim it out in cruise speed there is still a tendency to nose down... I'm lazy and don't want the back pressure... Do any of you guys use elevator trim and just move the flaperons full forward ? Also, it's a torquey little beast at full power... It likes a lot of right rudder on climbout... Should I bend the tail trim a little further and use the rt. rudder less on climbout our just get used to it ??? Any comments from you old pros will be gladly accepted... Steve Bennett Durham NC.
wingnut
Posted: Mon Sep 03, 2007 3:14 pm Post subject: Re: kitfox trim. |
Well.. I'm no "Pro" but I'll chime in with my limited experience
Are you trimming with flaps or do you have the motorized trim tab option? I have the trim tab on mine and there's plenty of trim authority to trim for strait and level. In fact, my trim setting is forward of neutral at cruise.
As for yaw: I too need lots of right rudder to stay coordinated on full power Vy climb. On the other hand, I still need a little left rudder at cruise. I spend a lot more time at cruise then I do at climb so that's more of a factor for me. I guess it's a trade off either way but there's no escaping that your feet are going to be a lot more busy in a Kitfox then they would be in your average Cessna.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Guy Buchanan
Posted: Mon Sep 03, 2007 7:37 pm Post subject: kitfox trim. |
At 03:34 PM 9/3/2007, you wrote:
| Quote: | When we try to trim it out in cruise speed there is still a tendency
First check the flaperons. You may have some flap on. I like the
flaperons to have the same angle of attack as the wing. Once you've
checked them, then I recommend adding an elevator trim. I like it
better than trimming with the flaperons, though I confess I've not
been able to ascertain a big speed difference either way.
| Quote: | Also, it's a torquey little beast at full power... It likes a lot of
I set the rudder trim for cruise and add rudder for going up and down hill.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
barry(at)pgtc.com Guest
Posted: Tue Sep 04, 2007 4:23 am Post subject: kitfox trim. |
My model IV has three holes at the leading edge of the horizontal stabilizer. I had to lower the leading edge to the lowest hole to get proper trim in cruise and then there is not much to spare. Nevertheless, I have no problem trimming for cruise and have left it that way for six years.
Barry West
dave
Posted: Tue Sep 04, 2007 7:20 am Post subject: Re: kitfox trim. |
Barry,
I have 3 holes on my IV as well -
--top hole for Wheel and skis
bottom hole when on floats.
fly hands free in straight and level flight.
Kitfox controls are essentially very light and I really have little need for trim although if I had it I would use it likely.
Dave
Posted: Tue Sep 04, 2007 10:41 am Post subject: kitfox trim. |
Dave, I used the bottom hole though mine is on wheels.
Barry
michaelgibbs(at)cox.net Guest
Posted: Tue Sep 04, 2007 7:14 pm Post subject: kitfox trim. |
Steve asks:
Have you checked the placement of the horizontal stabilizer leading edge? If the plane is otherwise rigged properly, maybe it needs to go into a lower hole.
| Quote: | Should I bend the tail trim a little further and use the rt.
I agree with the other responses you've gotten on this part: set the trim tab so you can put your feet on the floor in cruise. But don't leave them there...
Mike G.
N728KF, Model IV-1200
Phoenix, AZ
Lynn Matteson
Posted: Wed Sep 05, 2007 5:50 am Post subject: kitfox trim. |
On my initial flights, my test pilot and I moved the horizontal stab
as low as it would go and drilled a new hole to accommodate the front
attaching bolt. I then had to add a 3" tab to the trim tab to further
give enough trim control to the elevator. I have since cut the added
tab down to 2-3/4" because it is too sensitive to the electric trim
control. I'll probably cut one eighth at a time until it suits me.
This trim tab runs the full length...about 26"...of the electric trim
tab.
Lynn Matteson
flying w/400+ hrs
On Sep 3, 2007, at 6:34 PM, Sbennett3(at)aol.com wrote:
| Quote: | I recently purchased a kitfox 4 1200 with a rotax 912. When we
www.matronics.com/Navigator?Kitfox-List _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
kerrjohna(at)comcast.net Guest
Posted: Wed Sep 05, 2007 8:50 am Post subject: kitfox trim. |
Boy! This could become an embroiled discussion. My experience was just the opposite of Lynn's. Initially the horizontal was lowered to help "carve" around in the turns but we were not happy with the cruise trim. I believe we measured the flap setting to be 11 +/- degrees for level flight.
Ultimately, we moved the horzontal stab to its highest setting, sealed the horizontal/elevator gap and trimmed for level flight with the flaperons. We set the ailerons at neutral with the jib then flew to assess the situation. It took very little up (forward handle) trim from that point for level flight at 90-95 kts. We picked up speed because we were no longer dragging the flap, they were acutually a little reflexed.
We found that a little more rudder was needed in the turns but overall performance was improved significantly.
John Kerr
Classic IV/912, 766 hours as of this morning.
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: Lynn Matteson
tab.
Lynn Matteson
flying w/400+ hrs
> O ======
