FLUTING Ribs to match desired taper of VS
gareywittich2000(at)yahoo
PostPosted: Thu Sep 06, 2007 12:03 pm    Post subject: FLUTING Ribs to match desired taper of VS Reply with quote
Greetings:
Have an '"older" empennage and instructions dating
back to 1999. Understand RV-7, 8 and 9 have the same
Vert Stabilizer. Is there anything in the "Newer
Instructions" about about tapering (angling) the
flanges of the VS Ribs to match the desired contour
(taper) of the VS ???
Thanks, Garey
dhall(at)donka.net
PostPosted: Mon Sep 10, 2007 8:34 pm    Post subject: FLUTING Ribs to match desired taper of VS Reply with quote
No. The instructions don't say to match contour. 90 deg works.
Matching the contour really comes into play on the fuse bulkheads..
Don Hall
N517DG (registered)
rv7 fuselage
http://rv7.donka.net
