chenoweth(at)gwi.net Guest
Posted: Fri Sep 07, 2007 3:10 pm Post subject: wing gap seal |
I'm trying to figure out how the rubber seal between the wing gap seal and the fuselage is terminated along the bottom of the fuselage. I'm building a 9 tailwheel so there is no main gear fairing to cover the termination.
Do any of you tailwheel builders have suggestions on how to do this or perhaps a picture. Also, is it appropriate or necessary to glue the rubber seal to the gap seal? If so, with what?
Bill
Albion, Maine
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
aurbo(at)ak.net Guest
Posted: Fri Sep 07, 2007 3:45 pm Post subject: wing gap seal |
Bill,
I can't answer how to terminate the strip but perhaps I can help with the glue. I have used 3M contact cement (yellow) with great success when attaching rubber parts to Cessnas in the past. Just smear a light coat on each part, let dry, put them together and they will stick. This glue is real messy so tape off any place you don't want to glue.
Mike
bill(at)repucci.com Guest
Posted: Fri Sep 07, 2007 7:29 pm Post subject: wing gap seal |
Bill,
I just left mine about an inch long, for now. It will probably be glued to the fairing at some point but with 40 hours, it has only come off once, that gets your attention.
The glue I will use will be Automotive Trim Adhesive from Goop. It is available at most auto parts store. That is the same stuff I used to secure my zip-tie stand-offs after removing the adhesive square.
Bill
Posted: Sat Sep 08, 2007 4:23 am Post subject: wing gap seal |
Mike,
I guess I'm going to wait on the strip termination technique. We'll be a Sun n Fun again next year so I should have lots of samples to look at. Thanks for the glue idea - from what Bill R. said I suspect I can go without for a while or maybe just glue here and there.
Bill
Posted: Sat Sep 08, 2007 8:16 am Post subject: wing gap seal |
Bill,
I agree. Doesn't seem to be a big area for concern. Bill R. Has done it and is flying, good on him. He likes Goop and has used it a lot, I have more experience with the 3M weather strip adhesive. Both probably do the same thing equally well.
I do like the fact that Bill R., you and I are build 9's. Some day we might all get together at a 9 convention. A conventional geared 9 convention.
Mike
Posted: Sat Sep 08, 2007 4:36 pm Post subject: wing gap seal |
Mike,
You have it lucky up there, your summer time temps are as hot as ours here in the Carolinas. The Goop trim adhesive seems to hold, regardless of the OAT's and it remains flexible. That's why I recommend. I'm sure the 3M product is equally as good.
I'm game to get the -9's together.
On our return from the beach we stopped at a local airport for cheep fuel ($3.75/gal) and they had a big fly-in (Sky raider, P-51, DC-3, and a bunch of home builts.) We pulled up to the pumps, filled up, and left but in that time I was asked if my -9 was an RV-4, 6, 7, or 8, Swift, and a few others. One guy asked why I put a new cowling on my plane. He looked dumbfounded when I told him it was to match the new plane it was attached to. I don't think he understood even after I mentioned that I just finished building it.
Keep pounding those rivets guys, this -9 is one VERY nice flying bird!
Bill
kerrjohna(at)comcast.net Guest
Posted: Wed Sep 12, 2007 8:45 am Post subject: wing gap seal |
My gap seal run from rear of the top skin all the way around to rear of the bottom skin. I have not attached them with any adhesive and they stay in position. I can get photos if you wish.
John Kerr
[quote]-------------- Original message --------------
Bill
Albion, Maine
Posted: Wed Sep 12, 2007 11:33 am Post subject: wing gap seal |
John,
Thanks and if it's not too much trouble I would like to see what it looks like on the bottom of your plane.
Bill
