FAA reminder of the change to 406 MHz ELTs, in case you're
rvbuilder(at)sausen.net
PostPosted: Sat Sep 08, 2007 4:05 am    Post subject: FAA reminder of the change to 406 MHz ELTs, in case you're Reply with quote
Personally, I’m going with a 121.5 for now and then I will also be purchasing a 406 PLB like the Microfix. Of course this scenario requires someone to be conscious to activate the PLB
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill
Sent: Friday, September 07, 2007 9:42 PM
Subject: RE: FAA reminder of the change to 406 MHz ELTs, in case you're in the buying mood
I was actually thinking about this the other day. What are builders installing right now? TSO-C91a (121.5mhz/243mhz) or TSO-C126 (406mhz)?
As I understand it C91a still satisfies FAR 91.207 but will be of limited utility after Feb 1, 2007. I am curious as to what other builders are installing.
I haven't purchased one yet but was planning on a C126 unit.� They are all expensive and prices range widely. Does anyone have make/model recommendations for C126 devices?
Best Regards,
Patrick #40715
