NSI Isolation Module
n10pg(at)neo.rr.com
PostPosted: Thu Feb 16, 2006 10:30 am    Post subject: NSI Isolation Module Reply with quote
Hello NSI Subaru drivers:
Now that NSI is no longer in business, have any of you found a source for
the isolation modules that NSI used to manufacture? Or do you know of a
person or firm that can and/or will repair them? You do realize that if one
of these units gives up its ghost you are dead in the water.
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
morid(at)northland.lib.mi
PostPosted: Thu Feb 16, 2006 11:11 am    Post subject: NSI Isolation Module Reply with quote
Are you telling us that you're dead in the water Peter? I doubt that those
units were actually manufactured by NSI. The first person I'd call would be
Mykal Templeman at Stratus. As he worked for NSI for quite some time, if
anybody would know where to get one, he would. Are you sure it's the IM?
What are the symptoms?
Deke
one
Peter Graichen
Michael Logan
PostPosted: Thu Feb 16, 2006 2:59 pm    Post subject: NSI Isolation Module Reply with quote
The coil joiners or isolation modules are the weak point in the ignition of
the NSI setup. I have never heard of anyone having their ignition go bad
with the exception of some of us with the early models that had the pickups
go bad. Right now I am running without the modules on one ignition since my
modules went tango uniform on me.
Mike
Mike Logan
Fredericksburg, VA
smokey_bear_40220(at)yaho
PostPosted: Thu Feb 16, 2006 11:11 pm    Post subject: NSI Isolation Module Reply with quote
Haven't crossed that bridge yet Peter. I wonder if
the internal diodes have the manufacturer and
pertinent data stamped on them? If you are still
operating, leave it alone, but if not, getting at the
insides might be useful.
They are just big diodes, though handling high voltage
as they do must be a challenge for them. Still, I
haven't heard of any actually being the cause of
failure yet. I lost one P/U coil, but nothing more.
As far as I remember, you don't fix diodes. Only a
wire failure into or out of them is repairable. That
could possible be a problem with burnthru at a contact
point.
Kurt S.
Or do you know of a
the water.
Peter Graichen
Michael Logan
PostPosted: Fri Feb 17, 2006 6:01 am    Post subject: NSI Isolation Module Reply with quote
You can no longer get the original diodes that NSI put in the modules. You
can replace them with mouser electronics part number NTE 517 diode. It is a
higher voltage diode so you only need five rather than the six needed with
the original set-up. They are almost $6 each and you will need at least 40
of them if you are going to rebuild both modules.
Even rebuilt with new diodes, the module is still the weakest single point
failure point in the ignition system.
Mike Logan
Mike Logan
Fredericksburg, VA
PostPosted: Fri Feb 17, 2006 7:01 am    Post subject: NSI Isolation Module Reply with quote
I'm a little confused here Mike. Both modules? My NSI has only one
isolation module (coil joiner).
Deke
Michael Logan
PostPosted: Fri Feb 17, 2006 2:48 pm    Post subject: NSI Isolation Module Reply with quote
Mine has two, four wires in and two out on each. How is yours set up?
Mike
Mike Logan
Fredericksburg, VA
PostPosted: Fri Feb 17, 2006 10:19 pm    Post subject: NSI Isolation Module Reply with quote
Hi Michael,
I haven't dealt with such high tension diodes before,
but it seems to me likely that only one broke down in
the bunch. Do you know of a way to adequately test
these and replace only the bad one?
Obviously they will have to be seperated first for
testing. The problem I think is that it may test well
at low voltage or with a meter and only fail under
higher voltages.
This could be a more economical repair. But then I
wonder if unmatched diodes will cause a weaker one to
break down more quickly? I've not gone beyond 120
volt diodes in my experience.
Kurt S.
Mike Logan
Michael Logan
PostPosted: Sat Feb 18, 2006 7:51 am    Post subject: NSI Isolation Module Reply with quote
We tested all of the diodes in my bad module and they all tested good under
the normal testing. I have not dealt with these high voltage diodes before
so I am sure there is something that I am missing on the tests. There is
probably a special high voltage tester out there somewhere.
The old diodes have a rectangular cross section and the new diodes have a
round cross section. Makes it difficult to mix and match.
Mike Logan
Mike Logan
Fredericksburg, VA
PostPosted: Sat Feb 18, 2006 8:56 am    Post subject: NSI Isolation Module Reply with quote
OK Michael,
I wasn't sure if you were a spark guru or not.
These diodes are probably just like spark plug wires
in that they only show a fault when under high voltage
loads. There is always some voltage under which each
will break down. As they age and wear, that voltage
drops until it reaches the operating voltage and then
they fail. But something lower than that voltage may
still work.
If you were into playing around, you could make a
tester with a spark coil, some spark plug wire, a
little 12 volt wire, a momentary switch, a spark plug,
and a 12 volt battery. All you need to do is rig the
battery to the coil thru a momentary switch. Then,
off the high side, center post of the coil, run your
wire to the plug. Now the plug needs to be grounded
back to the coil with another spark plyug wire. That
is usually done by your engine block, but must be
added on the tester.
The spark will occur only at the moment you turn the
coil on or off from the battery thru the momentary
switch. The coil is AC activated and the battery is
DC, so it only blasts a spark as it turns on or off.
Keeping it on does nothing but run down the battery.
Test it and make sure it works as is first.
The diode should only allow the spark to go in one
direction. If it is failed, it will give a spark in
both directions. To test one, you put it in the line
between the coil and the plug. Test it both ways. If
it sparks only one way and not the other, it should be
good. If you get a spark both ways, it is bad.
Now the problem is that the NSI modules might create a
higher voltage spark than the coil you use, so you
need to get the highest voltage coil you can find.
Otherwise the test is not good for the modules
voltage.
Does any of that make sense? Hope it helps,
Kurt S. S-5/NSI turbo
the tests. There is
somewhere.
match.
Mike Logan
Michael Logan
PostPosted: Sat Feb 18, 2006 9:59 am    Post subject: NSI Isolation Module Reply with quote
Normally when a diode goes bad, it goes bad as an open which is what is
happening on these. When I was testing originally, I was getting fire on
the number one plug only part of the time which meant it was an open.
Thanks for the test procedure though. Maybe some day I will get up the
gumption to build a test set.
Mike
Mike Logan
Fredericksburg, VA
PostPosted: Mon Feb 20, 2006 1:55 pm    Post subject: NSI Isolation Module Reply with quote
OK, my mistake and apologies. I just went out and had a look and I hadn't
notice before that there were two separate units side by side. Always
thought it was just one unit.
I'm curious though Mike. I've been flying my NSI package since 2000 and
some on this list have been flying theirs much longer. This is the first
I've heard of any failures with the isolation module. Why do you say that
it's the weakest single failure point in the ignition system?
Also, can these units be dismantled for repair? They appear to be sealed
units. If I can expect to eventually have problems with mine I'd like to
know ahead of time what I'd need to be prepared for.
Deke
Mike
Michael Logan
PostPosted: Mon Feb 20, 2006 4:22 pm    Post subject: NSI Isolation Module Reply with quote
Deke,
If an ignition goes bad, you still have one left. If an isolation module
goes bad, you have no ignition on that plug if only one diode goes bad.
There has not been any failure of any of the ignitions that I know of.
I have had my IM's go bad twice. The first set cost me over $250 for NSI to
replace each module.
The modules are potted and you can get the potting material out but it is a
pain. You have to dig it out a little bit at a time.
Mike
Mike Logan
Fredericksburg, VA
