Posted: Fri Sep 14, 2007 1:45 pm Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
Uh Doc... I think highly of you my friend, but with all due respect, I
think the gas from the beans you ate last night might be influencing
your line of thinking here. Bernoulli's Principle does not apply in this
case. There is no "Venturi" no matter how hard you try to make it look
that way, and even if there was, the rules that impact the question do
not come from Mr. Bernoulli. Instead you might want to remember Mr.
Boyle. To wit:
The mathematical equation for Boyle's law is:
where:
p denotes the pressure of the system.
V is the volume of the gas.
k is a constant value representative of the pressure and volume of the
system.
So long as temperature remains constant at the same value the same
amount of energy given to the system persists throughout its operation
and therefore, theoretically, the value of k will remain constant.
However, due to the derivation of pressure as perpendicular applied
force and the probabilistic likelihood of collisions with other
particles through collision theory, the application of force to a
surface may not be infinitely constant for such values of k, but will
have a limit when differentiating such values over a given time.
Forcing the volume V of the fixed quantity of gas to increase, keeping
the gas at the initially measured temperature, the pressure p must
decrease proportionally. Conversely, reducing the volume of the gas
increases the pressure.
Boyle's law is commonly used to predict the result of introducing a
change, in volume and pressure only, to the initial state of a fixed
quantity of gas. The "before" and "after" volumes and pressures of the
fixed amount of gas, where the "before" and "after" temperatures are the
same (heating or cooling will be required to meet this condition), are
related by the equation:
p1V1 = p2V2
Boyle's law, Charles's Law, and Gay-Lussac's Law form the combined gas
law. The three gas laws in combination with Avogadro's law can be
generalized by the ideal gas law.
END QUOTE
So yes Tim... ANY line that you put between the tank and the original
line that is smaller than the original could CLEARLY cause this to
happen. In addition you have added LENGTH (I think?) If you have, then
your line from your new tank to where you hook it to the old line (did
you run it the whole way?) to be safe should have been even LARGER than
what was original.
Sorry to disagree with you Doc, but ... You must have been breathing
some of the NOS.....
Mark Bitterlich
N50YK
Posted: Fri Sep 14, 2007 6:20 pm Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
Mark,
You are absolutely correct in your reference to Boyle's law, Charles Law,
and Avagadro's law as they reference fluids at rest. In this case you are
looking at a fluid in motion. The term "fluid" applies to both a liquid and
a gas. A tube (line) having a constriction section between a larger diameter
inlet and the outlet section is called a "venture tube". In this case, a
smaller diameter tube in between two larger diameter tubes (lines). Whereas
point a is the entry point and point b is the exit point of the fluid as it
flows from the larger diameter tube to the end of the smaller diameter tube
you have introduced a constriction. So basically, you have flow thru a
constriction. In other words when you have a fluid flowing through a pipe of
varying cross-sectional area there can be no accumulation between a and b,
provided that fluid is incompressible. Hence the mass of the fluid passing
through the cross section A1 with speed v1 must equal the mass passing in
the same time (t) through cross section A2 with speed v2, where rho (p) is
the density of the fluid (since my computer does not do the Greek alphabet,
rho is p in this case).
A1v1pt = A2v2pt
So since A1v1 = A2v2, it follows that the speed of flow in a pipe is greater
in those regions where there is a constriction in the cross-section area
(A). [The smaller diameter tube (line)]. Furthermore, the speed is greater
at point b than at a, the fluid experiences an acceleration between a and b.
This requires an accelerating force. This accelerating force can be present
only if the pressure at point a is greater than the pressure a point b. So
in a steady flow of a fluid, the pressure is least where the speed is
greatest. So when a gas or a liquid enters the narrow part of the tube (the
constriction), it speeds up in the narrow part of the tube (line) and there
is a corresponding drop in pressure.
Bernoulli's theorem looks at the relationship between the pressure at any
point in a fluid and velocity of the fluid at that point. The movement of
the particles of fluid in a linear line through the tube is defined as a
streamline. Bernoulli's theorem states that at any two points along a
streamline the sum of the pressure, the kinetic energy per unit volume, and
the potential energy per unit volume has the same value.
Now the mathematical expression of that is as follows:
P1 +1/2pv1 squared + pgh1 = P2 = 1/2 pv2 squared +pgh2.
P = pressure
P = rho (density)
V = volumne
g = gravity
h = head [in a pressure- depth relation the depth (h) is frequently called
the "head"]. In a Pressure head, the h is equal to P/pg {p = rho (density of
the fluid) and g = gravity}
So applying Bernoulli's theorem to the case of a horizontal pipe that has a
constriction you can determine the rate of flow of the fluid passing through
if you know the pressure of the fluid and the area of the pipe at the widest
part or at the narrowest part by simply rearranging the equation for the
unknown.
So if you want to know P2 (the exit pressure for the narrow segment)
rearrange the equation to read as:
P2 = P1 + pg(h1-h2) +p/2(v1 squared - v2 squared).
Now having said all that, Bernoulli's theorem has many applications. The
carb is an atomizer, the filter pump is an aspirator, and our wing, the air
foil. Last but not least is the 2 year old child lying on the stretcher in
ER unable to breath due to bacterial epiglotitis obstructing the larynx
caused by Strep. In this case, the orifice (larynx) is narrowed by a
edematous epiglottis impeding flow of air. By manipulating the viscosity of
the gas by adding helium to the O2, we can support that child (maintain the
%Sat = 02 saturation) long enough to get them to the OR to intubate them. I
did not discuss viscosity as it affects the flow of a fluid through a
constriction did I?
For a further explaination, I refer you to College Physics by , Weber,
White, Manning and Waygand, Chapter 13, "Fluids in Motion", pp.241-255. Well
you do not have to go to my specific textbook, anyone that discusses fluid
mechanics can clarify this.
Doc
brian-1927(at)lloyd.com Guest
Posted: Fri Sep 14, 2007 9:01 pm Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
On Sep 14, 2007, at 7:19 PM, viperdoc wrote:
Mark,
Charles Law,
you are
liquid and
diameter
inlet and the outlet section ...
lots of stuff removed
| Quote: | Now having said all that, Bernoulli's theorem has many
applications. The
the air
foil. Last but not least ...
is a lot of stuff that really doesn't have any application.
Doc, sometimes a restriction is just a restriction.
(With apologies to Dr. Sigmund Freud.)
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
Scooter
Posted: Sat Sep 15, 2007 4:42 am Post subject: Re: UOTERE: Re: MF'ing air system! Yak-50 |
Well, just have to toss this in. These threads remind me of this classic monty python skit:
http://www.youtube.com/watch?v=y05EmK66Gsk
Posted: Sat Sep 15, 2007 4:49 am Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
Shack! And the pressure decreases in the restriction as the flow increases
with resultant turbulence/eddying/whatever to flow as it exits the
restricted area that results in loss of energy. That really is not lost when
considering that it is converted from kinetic to potential energy.
Bottom line is a restriction is a constriction that means Tim's gotta go on
the jacks again an listen for his affliction!
Good luck, Tim.
Doc
yakplt(at)yahoo.com Guest
Posted: Sat Sep 15, 2007 11:29 am Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
Doc...... I disagree.
Mark
viperdoc <viperdoc(at)mindspring.com> wrote:
[quote]--> Yak-List message posted by: "viperdoc"
Mark,
A1v1pt = A2v2pt
P = pressure
P = rho (density)
V = volumne
g = gravity
unknown.
constriction did I?
Doc
Posted: Sat Sep 15, 2007 1:57 pm Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
No sweety Da…
The # of the banoyete light bulb in my gear indicator is T1864!
Chec yo tips for grass stains :>)) I think there is only one YAK I would like to have more that the mighty 50…the 9! Check the 9 out on Airshow.com.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
Sent: Saturday, September 15, 2007 2:28 PM
To: yak-list(at)matronics.com
Subject: RE: UOTERE: Re: MF'ing air system! Yak-50
Mark
Mark,
A1v1pt = A2v2pt
P = pressure
P = rho (density)
V = volumne
g = gravity
unknown.
constriction did I?
Doc
ChangDriver
Posted: Sat Sep 15, 2007 6:14 pm Post subject: Re: UOTERE: Re: MF'ing air system! Yak-50 |
Doc:
Gotta give it to ya...pullin' out those old textbooks. I've packed mine away. However, from my engineering days, you are right on with Mr. Bernoulli. Air is a "fluid" that is in motion, hence his law applies.
By the way, some folks don't think Bernoulli's Law applies to aircraft wings as the reason for them generating lift. Check out http://www.allstar.fiu.edu/aero/airflylvl3.htm for a different view of lift!!
Craig
l39parts(at)hotmail.com Guest
Posted: Wed Sep 19, 2007 8:38 am Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
One guy's opinion is as good as the next in politics and religion, but
physics is testable, provable, and consistant. Bernoulli's law has nothing
to do with the gear retraction matter. Mark and Brian are right.
[quote]From: Yak Pilot <yakplt(at)yahoo.com>
Reply-To: yak-list(at)matronics.com
Date: Sat, 15 Sep 2007 12:28:14 -0700 (PDT)
Mark
Mark,
diameter
of
A1v1pt = A2v2pt
greater
b.
P = pressure
P = rho (density)
V = volumne
g = gravity
of
through
widest
unknown.
constriction did I?
Well
Doc
Posted: Wed Sep 19, 2007 8:39 am Post subject: UOTERE: Re: MF'ing air system! Yak-50 |
Mark
Mark,
diameter
of
A1v1pt = A2v2pt
greater
b.
P = pressure
P = rho (density)
V = volumne
g = gravity
of
through
widest
unknown.
constriction did I?
Well
Doc
