arholland
Posted: Thu Sep 13, 2007 3:03 am Post subject: 912S Oil and Water cooling issues |
I have a Kitfox Lite Squared. It is the same as the classic 4 except with a smooth cowl and is a tricycle. It has the GSC 3 blade prop. It has the 912S engine and has about 110 hours. My CHT runs about 230 and my oil temp runs about 230. I was running the waterless coolant and have switched to Prestone Dex-cool. With the Dex-cool it runs a little cooler on the CHT but the oil temp is still high. Also when the engine is at idle the oil pressure runs about 60psi, however when I am at cruise the oil pressure fluctuates between about 40psi and 60psi. Does anyone have any ideas to get the cooling under control and what could be causing the oil pressure fluctuations?
_________________ Allen Holland
Munford, TN |
clint_bazzill(at)hotmail. Guest
Posted: Thu Sep 13, 2007 3:02 pm Post subject: 912S Oil and Water cooling issues |
Thats strange. My problem is getting things warm enough. Model IV-1200 with oil cooler. 1250 hours. Clint
| Quote: | Subject: 912S Oil and Water cooling issues
Date: Thu, 13 Sep 2007 04:03:05 -0700
--> Kitfox-List message posted by: "arholland" <arholland(at)bigriver.net>
Allen Holland
Munford, TN
http://forums.matronics.com/viewtopic.php?p=134162#134162
pwmac(at)sisna.com Guest
Posted: Thu Sep 13, 2007 8:59 pm Post subject: 912S Oil and Water cooling issues |
Gauge or relief valve spring/piston seat???
Of course 230F is not very high. Fluctuation is a concern.
PW
| Quote: | >
> Allen Holland
> Munford, TN
