n616tb(at)btsapps.com Guest
Posted: Thu Sep 20, 2007 10:37 am Post subject: Canopy part way open latch |
Hi all,
I don't have any locks on my canopy but would like to put a latch of some
kind where it would stay open just about 4 inches. The problem is when I am
taxing I like to leave it ajar so I can get the breeze in. It doesn't
really stay there by itself as it tries to slide on back. It will stay if I
push it almost closed but then it is too easy to forget to latch it.
Does anybody have an idea or something they have done to put a small latch
inside for keeping it just a few inches open?
I am wondering about the stock locks that go in the canopy. They provide
for a means to lock in partly open as well but wasn't sure if that was
operable from inside without the key in the lock. Someday I may install the
stock lock system but it seemed so un-secure that I didn't really see the
point. I keep my plane in a hangar but when I travel it obviously is out on
the ramp.
Any ideas would be appreciated.
RV-6
dale1rv6(at)comcast.net Guest
Posted: Thu Sep 20, 2007 10:59 am Post subject: Canopy part way open latch |
I cut cereal box cardboard in an L shape. The long part is .25" by 1.5". the
other part is the handle. One or 2 layers is enough thickness to keep my
slider from sliding when put under the roller and rolling it back. You can
cut and fold in such a way to get 2 or 3 layers, and one layer can be
shorter to keep the roller from going back. Like a mini wheel chock.
Dale
ollie6a(at)embarqmail.com Guest
Posted: Thu Sep 20, 2007 11:01 am Post subject: Canopy part way open latch |
Tim,
I have a simple lock that has worked for years and is really simple,which I need.
I took a piece of piano wire and put a small loop in one end for a screw to fit through,then about 4-6 inchs from that I bent it 90* . I fastened this to the front of canopy near the roller and drilled a hole through the rail at the distance I wanted the canopy open. The 90* bend goes in this hole and the canopy stays open.Simpler to do than try and explain.
Ollie 6A Central Fl.
On 9/20/07, Tim Bryan <n616tb(at)btsapps.com (n616tb(at)btsapps.com)> wrote: [quote]--> RV-List message posted by: "Tim Bryan" <n616tb(at)btsapps.com (n616tb(at)btsapps.com)>
Hi all,
the ramp.
RV-6 [quote][b]
Posted: Thu Sep 20, 2007 11:22 am Post subject: Canopy part way open latch |
Check with the RV8 guys....when they're flying solo they wouldn't want that thing sliding all the way back.
I've got a note in to my local -8 driver - I know he did his that way.
