ChangDriver
Posted: Thu Sep 20, 2007 4:34 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
This web page gives a nice animated view of Bernoulli's Principle in action. Also, click on the link at the bottom for a discussion of "How Do Airplane Wings Really Work."
This should settle the debate on if Bernoulli's Principle applies to air moving from a supply tank to an actuator on a wing through a pipe with or without a constriction in the pipe..
I also think a number of folks stated that the pressure rises in the constriction, it does not....the pressure falls and the velocity of air increases. From my engineering days, we always said, "big pipe, big pressure."
As for how a wing works, I never got into all the boundary layer stuff, but it is a complicated thing that hangs on our planes and gives us the gift of flight. Bernoulli only plays a small part (if at all). However, it is the easiest way to explain it with out a bunch of mumbo jumbo so the FAA and everybody else continues to promote Bernoulli as the reason our planes fly.
http://home.earthlink.net/~mmc1919/venturi.html
ENJOY!!!!!!
Craig Winkelmann, CFI
"The fruit of love is service. The fruit of services is peace, and peace begins with a smile."
- Mother Theresa
Posted: Thu Sep 20, 2007 7:46 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Hi Craig!
Thanks for the link. I read it. Really nice graphics! Let's skip to
the chase.
As far as Bernoulli applying to the problem at hand when viewing it as
an expression of the conservation of energy, I agree completely.
However, the problem being discussed deals with the movement of a piston
that is driven by a compressed gas and therefore I feel is better
described as "System Work". Work equaling Pressure Delta Volume The
definition of work becomes W=Fd for a constant force F along a distance
d. Using the definition of pressure: W= F/A (Ad)= P Delta V The above
assumes a constant pressure source, which obviously we really do not
have, but close enough.
So what I have been trying to say is that while Bernoulli will indeed
completely describe the varying pressure, flow rates and velocities
through pipes of varying sizes, (I.E. from the tank TO the actuator) it
is not really meant to describe the process of using a compressed gas to
accomplish the job of lifting the landing gear on a YAK-50, which was
what I assumed was being discussed in the original article. Possibly I
assumed incorrectly. I also earlier was trying to describe how one
determines how much energy is CONTAINED in a compressed gas and once
again said that Bernoulli's laws do not apply. So before anyone differs
with what I said (as in right, wrong, indifferent make sure we are
all clear on what I was trying to say to begin with. The fault again
possibly being my own for not being clear enough. I make that mistake
ALL the time by the way.
I guess in the end it is a matter of semantics as in order to use the
System Work law you still have to compute end state P and V after all
the line size changes, and what should have been obvious to begin with
is the size of the flow restrictor that is inserted right at the
actuator..... It really being one of the the main determinants anyway
since it is smaller than any line in the system to begin with, probably
including the new line that Tim installed. It also lends a
visualization of how small the constriction would have to be to cause
Tim's problem assuming no leaks.
One thing though... For Bernoulli's Principle to apply, the fluid is
assumed to have the same density everywhere (it is "incompressible" like
water.
Does the compressed air in our systems meet this definition? Yes, no?
Just curious how you would view the answer to that question Craig.
Thanks for pointing out an excellent web site.
Mark Bitterlich
N50YK
brian-1927(at)lloyd.com Guest
Posted: Fri Sep 21, 2007 9:04 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
On Sep 20, 2007, at 8:45 PM, Bitterlich, Mark G CIV Det Cherry Point,
MALS-14 64E wrote:
| Quote: | One thing though... For Bernoulli's Principle to apply, the fluid is
like
water.
No. We are clearly dealing with a compressible fluid as the pressure
on either side of the restriction is different.
We *were* talking about a pipe with an unintended restriction that
causes a large pressure drop between the storage tank and the rest of
the system.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
Ernie
Posted: Sat Sep 22, 2007 5:55 am Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Magnus has no effect on the burrple destrofunkenspicthen, when bernouli tickles his testicular nipplefricker. Now on the other hand, if you diassemble the pooter evector during a combined molecular fusion butterjamtoastgotshitonmyshirt event, then you may ripp the goddam wings off of the plane.
Ernie
HawkerPilot2015
Posted: Sat Sep 22, 2007 10:37 am Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
| Ernie wrote: | Magnus has no effect on the burrple destrofunkenspicthen, when bernouli tickles his testicular nipplefricker. Now on the other hand, if you diassemble the pooter evector during a combined molecular fusion butterjamtoastgotshitonmyshirt event, then you may ripp the goddam wings off of the plane.
Ernie |
Exactly.....
(The new spell checker went nuts on this)
HawkerPilot2015
Posted: Sat Sep 22, 2007 10:38 am Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Ernie |
Exactly.....
HawkerPilot2015
Posted: Sat Sep 22, 2007 10:53 am Post subject: More observations.....from the MF'ing air system. |
I spoke to the mechanic who did the work on my airplane. Before anyone jumps on him for "shoulda known better", the guy does amazing work and the use of the a smaller diameter line was talked about. His lack of experience with Yaks and my...hmmm...lack of thorough knowledge lead us towards using the fill line from the fill port instead of running a new line from the new bottle (behind my seat). So, we will replace the line with one of original diameter. We will also check for leaks....
Sooo......a few observations from todays flight and something that may add a wrench to the works...OR....turn a light bulb on for someone.
Go to the airplane to fly this morning. Gauge reads about 40. Turn on the main valve, pressure drops to about 20. Hmmmm...small leak somewhere downstream of the bottle? (The airplane has been sitting for about a week or so) She starts perfectly after a few blades, I let her warm up to 120c+ and when I push the lever forward, I have about 40 ATM. This is after about 6 or 7 minutes from start to throttle up for take off. Making good pressure. Lift off, gear handle up, that big pressure drop (20+ atm) but gears comes home nicely with a reassuring thump. Pressure rebuilds to >55 ATM after somewhere between 5-10 minutes of flying. Go flip around a bit, come back into the pattern, gear down off the perch, big pressure drop (same pressure drop) and gear thumps nicely. Land with about 25 atm in the airplane. Run up, pressure builds back up to 40 or so, but did something new this time....hopefully not unsafe.
Brakes on, run up to 70% for about a minute, pressure builds to about 40, then I SHUT OFF (engine still running) the main valve and the pressure builds to about 55 ATM and I shut her down.
I have some thoughts but want to verify mine with yours....you guys are way smarter than I am.
I am glad this thread has generated some healthy, yet calm, discussion. I have learned much...
One more question. What are you guys normal oil temps in cruise at a crusie power setting.
yakplt(at)yahoo.com Guest
Posted: Sat Sep 22, 2007 11:15 am Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
I am starting to wonder whether you might just have a bad gage. Checked for that yet?
Mark
Tim Gagnon <NiftyYak50(at)fuse.net> wrote:
[quote]--> Yak-List message posted by: "Tim Gagnon"
Brakes [quote][b]
HawkerPilot2015
Posted: Sat Sep 22, 2007 11:39 am Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Nope...but I will add that to the list of things to check!
ChangDriver
Posted: Sun Sep 23, 2007 6:03 pm Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Tim:
Is there any possible way for there to be a leak from the main system to the backup/emergency system?? Why would your pressure go UP when you shut off the main system? What is your emergency air pressure when you start, fly, move gear, etc?
Craig
HawkerPilot2015
Posted: Sun Sep 23, 2007 6:30 pm Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
| Craig Winkelmann, CFI wrote: | Tim:
Craig |
Steady at 60. The needle does not move at any time....
jan.mevis(at)informavia.b Guest
Posted: Sun Sep 23, 2007 11:39 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Anyway, aerodynamics is a very complex science, and what pilots usually
(have to) know about it, is quite limited. To calculate aerodynamic forces,
you also need the theorem of Blasius and its modern variants for subsonic
speeds. Lots of complex analysis and contour integrals ...
Jan
YK50 RA2005K
Posted: Mon Sep 24, 2007 10:53 am Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
The pressure goes UP in the main system because when you shut the valve
to the tank on a 50, the compressor is still creating more air pressure,
and will continue to build pressure until the pop-off valve is released.
Thus if you shut off the tank at 40, the gage will continue to show the
pressure increase until the valve pops and releases as per normal
operation.
The 50 DOES also charge the emergency bottle as well as the main bottle,
unlike the 52.
Scooter
Posted: Mon Sep 24, 2007 3:18 pm Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
But is the system only going from 40 to 55atm after the main valve is shut off (and not before)? If so then it seems there must be a leak somewhere downstream of the main valve.
| mark.bitterlich(at)navy.m wrote: | The pressure goes UP in the main system because when you shut the valve
operation.
unlike the 52.
Posted: Mon Sep 24, 2007 4:34 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Good question//point.
Yes, if the bottle only fills to 40 and will not fill further, and then
when you close it, the gage goes rather quickly to 50 then your
hypothesis must be correct.
Mark
ChangDriver
Posted: Mon Sep 24, 2007 5:35 pm Post subject: Re: Bernoilli, His Equation, Air Moving in Pipes and Flight |
My vote is for a downstream leak. With main off, tank fills to 55 easily. With main open, in flight, etc, can only get to 40 so compressor is working but can't keep up with the leaking air to get tank to 55. 40 is enough to move gear but excessive loss of pressure is from a leak when you are moving more air through the system by activating the gear (leak plus air needed to move gear).
BTW, Tim says emergency air pressure is rock solid at 60.
Does this make sense to Mark and others?
Craig
Posted: Mon Sep 24, 2007 6:43 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Guys,
What makes sense is a set of jacks and a gear retraction test done on those
jacks. Otherwise this is all mental masturbation.
Doc
Posted: Tue Sep 25, 2007 12:50 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Tim take note: Downstream leaks that are not apparent on the deck means
that they are happening only when putting the gear handle up right?
Keep in mind that you can take the landing gear handle on the 50 and
after raising the gear, move it back down to the MIDDLE POSITION. This
will totally isolate the landing gear from the air system. After doing
that, take a look at how fast your air gage gains pressure and holds it.
If there is a difference, then there is probably a up side only leak.
This is a much different test than just shutting off your air tank
itself. EVERY Yak-50 will see a rapid increase in pressure once you
shut off the air tank simply because you are just filling the lines
themselves and not a tank any longer. I ferried a YAK-50 to California
using this method, so it works... Perfectly.
ONE WARNING. You MUST move the handle back to the UP POSITION before
then putting it back to the DOWN position to lower the gear. If you
fail to do this, the landing gear is going to come down a lot faster
than you've ever seen, and with possible damage.
Another factor here... In flight once stabilized, if you put the landing
gear handle in the middle and then come back to the UP position and you
lose a bunch of air immediately, this is again an indication of an UP
side leak.
It is entirely possible to have a one way leak on a YAK-50 actuator.
Of course, if it were me, that aircraft would have been jacked and
cycled 5 times by now. What's the hold up?
Mark
jonboede(at)hotmail.com Guest
Posted: Tue Sep 25, 2007 7:50 pm Post subject: Bernoilli, His Equation, Air Moving in Pipes and Flight |
Be it known, Ernie... that your gift for summing things up does not go
unnoticed or unappreciated.
| Quote: | From: "Ernie" <erniel29(at)gmail.com>
Reply-To: yak-list(at)matronics.com
Subject: Re: Bernoilli, His Equation, Air Moving in Pipes and
Flight
Date: Sat, 22 Sep 2007 06:55:46 -0700
off of the plane.
Ernie
http://forums.matronics.com/viewtopic.php?p=135747#135747
