tdawson-townsend(at)auror Guest
Posted: Sun Sep 23, 2007 12:12 pm Post subject: throttle, etc cables |
I ran my throttle, prop, and mixture cables over the bottom bar of the engine mount, like shown on the FF plans. Seems like not a lot of room in there and potential for rubbing. Did other folks do the same, or let the cables go under the bottom bar of the engine mount?
TDT
VHMUM(at)bigpond.com Guest
Posted: Sun Sep 23, 2007 12:25 pm Post subject: throttle, etc cables |
My cables were not long enough as supplied by FF kit and using the pre punched holes in firewall so I made new holes in the fire wall and run the cables under the bar and clamped them.
regards Chris
bgill1(at)charter.net Guest
Posted: Sun Sep 23, 2007 5:51 pm Post subject: throttle, etc cables |
I ran mine under the bar – but also did not have enough cable length. I am using a canted center panel that my knobs mount on - this takes up an extra inch or so leaving me buying a new set of cables. But like you, It looked like over time it might get a little close – so I didn’t want to take a chance.
Byron
Wrapping up the panel install
N253RV Assigned
