sarg314(at)comcast.net Guest
Posted: Fri Sep 21, 2007 5:09 pm Post subject: CHT accuracy |
My old old VM1000 which sat in a box for about 6 years is running now
and showing 15 - 20 deg. F low readings on CHT3. (Using 160 - 190 deg.
water to test the with.) I've swapped cables and thermocouples and even
the socketted multiplexor chips that the thermocouples connect to. The
low readings always stay with CHT3. The same cable connected to a
different channel works OK.
In talking to what's left of vision micro, the guy seemed to not be too
disturbed by a 20 deg. error. A 5 deg. error would certainly not be a
problem, but I think 20 deg. is getting too big for a parameter that you
want to see stay below 400 deg. What kind of accuracy do people
normally expect in CHT readings?
Tom Sargent,
RV-6A, electrical system.
