Posted: Sun Sep 23, 2007 2:53 am Post subject: space |
Hi All,
Anyone with an Xtra with the standard insrument console.
Where do you put radios, GPS etc.?
I have the small Pilot 3 GPS on top of the console. The obvious place to put a hand held radio is either fixed to the centre arm rest or strap it to your knee. I have a small interface block for the headsets temporarily taped to the back end of the armrest.
What have other people done? The great visibility from the Kolb is fine but it does limit the `wall space` for fixing othere items, map holders, sweets etc.
Bright ideas anyone?
Cheers
Pat
Richard Pike
Posted: Sun Sep 23, 2007 3:36 am Post subject: space |
You can actually attach things to the "wall" as here:
http://www.bcchapel.org/pages/0003/Radios%20%26%20GPS.html
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Sun Sep 23, 2007 5:58 am Post subject: space |
Pat, what armrest?
Vic
Maine
MKIIIX
_________________ MKIIIX040
912UL |
Posted: Tue Sep 25, 2007 7:05 am Post subject: space |
You can actually attach things to the "wall" as here:>>
Thanks Richard, I was reluctant to go down that route,what with the complications of opening doors etc. but your brackets look good and firm and I may have to consider your way.
Pat
Posted: Wed Sep 26, 2007 1:40 am Post subject: space |
Pat, what armrest?>>
Hi Vic,
I have a piece of metal fitted over the rod from the stick to the aileron. It is about 18" long and 3" wide on the flat top and has side cheeks bent down to enclose the aileron rod.
About the only place anything can be atached on the Xtra. Poor ergonomic design where everything was sacrificed to produce the fantastic visibilty and that admittedly very shapely nose.
Pat
