GAMarr(at)charter.net Guest
Rhino
nuckolls.bob(at)cox.net Guest
Posted: Fri Sep 28, 2007 9:18 am Post subject: FAA Policy on Circuit Breakers |
At 09:07 AM 9/28/2007 -0500, you wrote:
Bob
You may find this FAA Designee Newsletter of interest.
http://tinyurl.com/2hpesb
Yes, it was interesting in a disappointing sort of
way. Here's an analysis of the document:
http://aeroelectric.com/articles/Testing_in_Aircraft_with_EFID.pdf
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
hooverra(at)verizon.net Guest
Posted: Fri Sep 28, 2007 4:06 pm Post subject: FAA Policy on Circuit Breakers |
I must agree with Bob on his response to this but an even simpler
analysis is that the writer missed half of the breaker definition and
assumed design intent!
"AC 23-17B, System and Equipment Guide for Certification of Part 23
Airplanes, (Amendment 23-49 and Subsequent) For part 23 applications,
the definitions of a switch and a circuit breaker are as follows: 1) A
switch is a device for opening and closing or for changing the
connection of a circuit; 2) A circuit breaker is a device designed to
open and close a circuit by non-automatic means and to open the circuit
automatically at a predetermined overload of current, without injury to
itself when properly applied within its rating. Thus, circuit breakers
used for operational functions are not acceptable because they are not
performing their intended function, which is protection against
overloads. "
According to the above definition the functions of a breaker are *"open
and close a circuit by non-automatic means" *and *"to open the circuit
automatically at a predetermined overload of current"*. To conclude
using the breaker as a switch is not acceptable assumes that only the
second part of the definition is intended. If the breaker is the
pullable type then switching is an intended function. If the designers
intent was to restrict the use of the breaker as a switch then a
non-pullable breaker could be applied. I would assume that if the intent
was to restrict the switching function of a pullable breaker then a
caution should be applied near the breaker or at least in the operation
instructions.
Just my two cents.
Ralph C. Hoover
RV7A
hooverra at verizon dot net
Posted: Fri Sep 28, 2007 6:06 pm Post subject: FAA Policy on Circuit Breakers |
At 08:06 PM 9/28/2007 -0400, you wrote:
I must agree with Bob on his response to this but an even simpler analysis
is that the writer missed half of the breaker definition and assumed
design intent!
overloads. "
automatically at a predetermined overload of current"*. To conclude using
the breaker as a switch is not acceptable assumes that only the second
part of the definition is intended. If the breaker is the pullable type
then switching is an intended function. If the designers intent was to
restrict the use of the breaker as a switch then a non-pullable breaker
could be applied. I would assume that if the intent was to restrict the
switching function of a pullable breaker then a caution should be applied
near the breaker or at least in the operation instructions.
Just my two cents.
Ralph C. Hoover
Interesting take. I missed that. I'm trying to put the
gray-matter around:
"Thus, circuit breakers used for operational functions are
not acceptable because they are not performing their
intended function, which is protection against overloads."
Does this mean that IF you use a breaker for any purpose,
it's first function is for protection and switching is
secondary? Therefore, the antithesis would suggest that
if one uses a breaker primarily for it's capabilities
as a switch and intent for protection is claimed,
then the designer is to be shot at dawn?
kuffel(at)cyberport.net Guest
Posted: Sat Sep 29, 2007 5:56 am Post subject: FAA Policy on Circuit Breakers |
The FAA sez:
"A circuit breaker is a device designed to open and close a
injury to itself when properly applied within its rating. Thus,
circuit breakers used for operational functions are not
acceptable because they are not performing their intended
This is a typical case of bureaucratic blindness. It ignores the
existence of breakers *designed* to also be used as switches.
The hydraulic/magnetic series from Airpax and Carling cost $15 -
$20 each. I claim their trip point is more stable than the
ambient temperature sensitive thermal types we typically use.
And the lower parts count of combining the switch and breaker
function simplifies wiring which almost by definition increases
reliability.
This ability to use technologies more modern than W.W.II is yet
another advantage of OBAM aircraft.
Tom Kuffel
handainc(at)madisoncounty Guest
Posted: Sat Sep 29, 2007 7:50 am Post subject: FAA Policy on Circuit Breakers |
Which part numbers do you recommend for aircraft 12 VDC use?
M. Haught
The Kuffels wrote:
<kuffel(at)cyberport.net>
The FAA sez:
"A circuit breaker is a device designed to open and close a circuit by
non-automatic means and to open the circuit automatically at a
predetermined overload of current, without injury to itself when
properly applied within its rating. Thus, circuit breakers used for
overloads."
existence of breakers *designed* to also be used as switches. The
hydraulic/magnetic series from Airpax and Carling cost $15 - $20
each. I claim their trip point is more stable than the ambient
temperature sensitive thermal types we typically use. And the lower
parts count of combining the switch and breaker function simplifies
wiring which almost by definition increases reliability.
Tom Kuffel
Posted: Sat Sep 29, 2007 8:14 am Post subject: FAA policy on circuit breakers |
Hi All-
> gray-matter around:
as a switch and NO intent for protection is claimed,
Why, yes- of course!
My take on the FedWords is that CB's are not to be used as switches as a matter of course. However, there have been times when an electrical problem has caused smoke / fire without drawing adequate current to trip a CB. For example, a low power component inside a high powered box could fail dramatically, causing fire / smoke without tripping the protection for the box. (think Swissair) SOP for these situations is to make ones way through the electrical system, pulling breakers until the faulty circuit is isolated and depowered. Hence, the breaker is being used for an emergency, as opposed to operational, function.
regardz-
Glen Matejcek
Posted: Sat Sep 29, 2007 8:47 am Post subject: FAA Policy on Circuit Breakers |
At 10:49 AM 9/29/2007 -0500, you wrote:
<handainc(at)madisoncounty.net>
ANY breaker you find in the catalogs will function
as expected for the purpose of keeping your airplane
from catching fire. It's a matter of how much $time$
and panel space you are willing to invest in procuring,
installing, wiring and carrying them around for the
lifetime of the airplane.
The breakers of choice for most builders is the same
device used in the majority of type certified aircraft.
Exemplar devices look like this:
http://www.aeroelectric.com/Pictures/Breakers/circuitbreakers.jpg
and are offered by
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?7X358218#cb25
http://aircraftspruce.com/menus/el/circuitbreakers.html
http://steinair.com/circuitbreakers.htm
http://www.wicksaircraft.com/catalog/product_detail.php/pid=1826~subid=629/index.html
The greatest return on investment is to not use fuses
in lieu of breakers:
http://www.aeroelectric.com/Pictures/Fuses/fuseblks.jpg
http://www.aeroelectric.com/Pictures/Fuses/s889.jpg
AV8ORJWC
Posted: Sat Sep 29, 2007 10:36 am Post subject: FAA policy on circuit breakers |
Glen - thanks for clear language to help in "To use or not use" CBs. In
our air transport aircraft, a flight crewmember can "Open" closed
circuit but only on rare occasion close a CB which is provided for its
primary purpose - to protect the wire. No one should assume the CB is
installed to protect the end component(s).
Trained maintenance personnel operating on the ground with the flight
formally terminated may then troubleshoot and close an errant CB.
The CBs are designed and constructed to aid in Operator assisted
"opening". They are assumed to always be in the ready to serve their
primary purpose "to protect the wire run" when Closed. The Fed requires
that our technical department brief the pilots not to close them except
in isolated and pre-approved in-flight conditions.
We are briefed that they are only used as switches and moved between
"Off (open) / ON (closed)" while on the ground, in maintenance mode and
with other personnel present.
To second a comment that was projected earlier, I do not consider
installation of CBs on the primary flight instrument panel to be a
prudent use of valuable real estate. Nor are they particularly
aesthetically pleasing to look at for the life of the panel. Leaves a
conundrum as to where to place them, how easy to read/see which one pops
Open and how easy to open them when necessary as a procedural switch
during that rare occurrence.
John Cox
Posted: Sat Sep 29, 2007 1:03 pm Post subject: FAA Policy on Circuit Breakers |
I guess I wasn't clear, as I was referring to the breakers that are also
designed as switches, re: the Airpax and Carling units. I googled a
site that has them, and was totally boggled by the variety and number of
possibilities. Makes sense to me to cut down on parts count, and every
where I need a switch and a circuit break, I would considered using one
of those units. However, I can visualized HOURS poring through that
site trying to find a suitable 12 volt unit. I'm very familiar with
aircraft circuit breakers and have several surplus breakers in my stock
of parts for replacement of units in my certified Pacer. Just thought
it was interesting to be able to cut down on complexity, connections and
number of parts by using the dual purpose breakers / switches.
I'm building a Bearhawk and am primarily interested in reliability and
simplicity (I believe both of those characteristics go hand in had from
my personal experience with airplane electrical systems!).
However, Bob, I certainly appreciate you taking the time and making the
effort to educate a "newby". By the way - I attended one of your
seminars nearly 20 years ago now, and that is where I obtained my basic
education on aircraft wiring. I was glad to find this site as I am
starting to plan my electrical system for my Bearhawk.
M. Haught
khorton01(at)rogers.com Guest
Posted: Sat Sep 29, 2007 3:42 pm Post subject: FAA policy on circuit breakers |
On 29 Sep 2007, at 14:34, John W. Cox wrote:
| Quote: | To second a comment that was projected earlier, I do not consider
pops
I agree that CBs should be located so that they can be confirmed as
IN during pre-flight checks. But once you are in flight, I am not
convinced that we need easy view or access. Typically the first sign
of a problem is when you notice that some piece of equipment is no
longer functioning. At that point, does it really matter whether the
failure is caused by a popped CB, a wire that has come off a
terminal, or a failure of the item itself? Why do you need to be
able to easily see the CB?
If a piece of equipment has a potential failure mode that would
require removing its power supply, it should probably be wired
through a switch, or you should plan on killing power to the bus that
powers it (only acceptable if you can accept the loss of all other
items on that bus). You shouldn't plan on pulling the CB, as they
can sometimes be very difficult to grab on to.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Kellym
Posted: Sat Sep 29, 2007 7:13 pm Post subject: FAA policy on circuit breakers |
Hi John,
Remember that a number of type certificated aircraft are equiped with
circuit breakers such as the P&B W31 series that are intended to be
routinely used for switching devices on and off, as well as providing
circuit protection. Of course that is from the CAA days, when the feds
actually had some folks that knew something. Lets see, my TC aircraft
has boost pump, pitot heat, rotating beacon, nav lights and landing
lights on such breakers on its type certificate, and a couple more added
later for STC approved equipment.The only failure mode I have seen is
the internal springs get weak with age and they can nuisance trip, at
which point they are due for replacement.
Kelly
John Cox
KCHD |
Posted: Sun Sep 30, 2007 11:00 am Post subject: FAA policy on circuit breakers |
At 08:11 PM 9/29/2007 -0700, you wrote:
Hi John,
actually had some folks that knew something. Lets see, my TC aircraft has
boost pump, pitot heat, rotating beacon, nav lights and landing lights on
such breakers on its type certificate, and a couple more added later for
STC approved equipment.The only failure mode I have seen is the internal
springs get weak with age and they can nuisance trip, at which point they
The W31 switch breakers don't exercise the
components that calibrate circuit breaker
trip when the switch portion is operated.
See:
http://www.aeroelectric.com/Pictures/Breakers/W31_3.jpg
http://www.aeroelectric.com/Pictures/Breakers/W31_2.jpg
http://www.aeroelectric.com/Pictures/Breakers/W31_1.jpg
Note that the trip latch and heater strut
maintain a constant, non-moving relationship
with each other as the switch side transitions
the contacts from closed to open.
Here's an excerpt from a posting I did about 2 years
ago on this product:
These are the switch breakers I've mentioned on several occasions
in the past and featured in the comic book at:
http://aeroelectric.com/articles/Breakers/Breakers.html
The failure mode cited is NOT a short but an open that causes
the load path to shift. In the picture at:
you can see the two copper wire jumpers across moving
joints made up of little ropes of exceedingly fine strands
of wire. These are RATED at many thousands of cycles on the
data sheet . . . but it seems that the sum total of environmental
stresses as-installed are such that these critters fail in a few
thousand cycles. The failure begins as a breaking (or fusing)
of the last remaining strands of jumper.
This happens in the upper jumper. When that pathway is lost,
the switch-breaker's current still flows through the spring
that is intended to open the switch contacts when the lever
is moved to OFF. This spring is capable of carrying current
in the switch-breakers of smaller size . . . 5A and 10A but
in the Prop DeIce circuit of a Bonanza or Baron, the current is
so great as to cause the spring to glow cherry red and cause
surrounding plastic cases to char. This is what produces the
smoke. The amount of smoke was not nearly worthy of the doom
and gloom inferred by the AD.
The "fix" was to insert the plastic insulating sheet you can
see in the inside, upper left corner of the metal frame. This
prevents the spring from becoming a secondary load path and
the breaker fails passively by simply allowing the downstream
load to go OFF.
Cessna's decision to use this product as a master switch-breaker
was unfortunate. There was no need for this device to be a breaker too.
Selection of this part drove parts count up and drove reliability
down. If you must have an avionics master switch, the plain-jane
toggle is the device of choice. Better yet, leave it out entirely.
Switch=breakers are an entirely different breed of
cat. They're not vulnerable to the adverse performance
conditions demonstrated by routinely using a pull-type
circuit breaker as an operating switch. This is also
a separate issue from the discussion about adverse
effects on a switched system whether by pulling a breaker
or interrupting power by any other means.
MaxNr(at)aol.com Guest
Posted: Sun Sep 30, 2007 9:19 pm Post subject: FAA Policy on Circuit Breakers |
I have been lurking on this list for a while trying to learn a little about electrical systems, but I cannot bite my tongue any longer. As stated in AC 120-80, the manufacturer many times in the Flight Manual includes the use of C.B.s to disable systems to check systems on run up or to deal with in flight malfunctions or emergencies. Some C.B.s have colored collars to help in locating in emergencies. Available at ACS, Sporties and other fine shops. The last A/C (Sikorsky 76 series) that I flew before retiring was such an A/C. Most C.B.s don't even have a corresponding on/of switch. I have a lot of war stories where we got things back under control by finding and pulling the right C.B. Chip lights for example. As for resetting in flight: About 25 years ago, I was single pilot, had passengers on board and trying to land in heavy rain. The Pilot's Windshield Wiper C.B. repeatedly popped. I used my emergency options as PIC to hold the C.B. in and chance a fire in order to land (one handed) safely. You got to do what you got to do. There was no fire, maintenance readjusted the wiper tension and all was fine. As for simulating EFIS failure, they all have a brightness knob and you can make it go dark that way. It will then go into reversion mode for you. I discussed the subject bulletin this evening with my friend who is a Maint Inspector/AI for my old company. He lost it. The only thing that he said that was printable on a family web site was something about "know nothing white shirts hiding in the FAA office." Sorry for pouring gas on a fire. I'm retired remember.
RTD
See what's [quote][b]
wjoke(at)shaw.ca Guest
Posted: Sun Sep 30, 2007 10:17 pm Post subject: FAA policy on circuit breakers |
Kevin Horton wrote:
<khorton01(at)rogers.com>
I agree that CBs should be located so that they can be confirmed as IN
failure is caused by a popped CB, a wire that has come off a terminal,
or a failure of the item itself? Why do you need to be able to easily
see the CB?
require removing its power supply, it should probably be wired through
a switch, or you should plan on killing power to the bus that powers
it (only acceptable if you can accept the loss of all other items on
that bus). You shouldn't plan on pulling the CB, as they can
Ottawa, Canada
One example of the situation Kevin describes in his second paragraph is
the aileron trim on the FAR 25 aircraft I fly in my 'day' job. If it
quits dead due to motor burn out somewhere near the neutral position
that's one thing. If the operating rocker switch fails so as to drive it
to full travel in one or the other direction that's another and probably
more demanding situation with obvious aircraft handling implications.
The manufacturer's procedure for a runaway trim is to attempt to use the
operating switch to drive the trim to neutral and then pull the
associated circuit breaker to stop the trim in something close to the
neutral position. In this case there are lots of circuit breakers
relatively easy to access from the pilot seats so not really an issue to
add one more for the aileron trim for the once in 10,000 (or whatever)
flying hour that it needs to be pulled to disable the trim. The
alternative would be to add a dedicated trim disable switch that would
add parts and likely decrease overall reliability.
Of note, just about all the other 120 or so CBs on the airplane are
treated as "never reset except in dire emergency" devices.
Jim Oke
RV-6A
Wpg., MB
Posted: Mon Oct 01, 2007 8:03 am Post subject: FAA policy on circuit breakers |
| Quote: | >--
>Ottawa, Canada
the aileron trim on the FAR 25 aircraft I fly in my 'day' job. If it quits
dead due to motor burn out somewhere near the neutral position that's one
thing. If the operating rocker switch fails so as to drive it to full
travel in one or the other direction that's another and probably more
demanding situation with obvious aircraft handling implications. The
operating switch to drive the trim to neutral and then pull the associated
circuit breaker to stop the trim in something close to the neutral
position. In this case there are lots of circuit breakers relatively easy
to access from the pilot seats so not really an issue to add one more for
the aileron trim for the once in 10,000 (or whatever) flying hour that it
| Quote: | The alternative would be to add a dedicated trim disable switch that would
Yes, when parts count goes up, probability of a failure in that
system or sub-system goes up . . . but let us take care that we
do not equate high "system reliability" with low "cost of ownership".
A runaway trim with poor mitigation features translates to lower
system reliability because the pilot is likely to "break a sweat"
or worse, wrinkle the airplane and occupants.
A failure in a rapid response shutdown system (wheel master disconnect)
is pre-flight detectable and has a minor effect on pilot workload
for the various failure mode effects. And yes, the presence of extra
electro-whizzies has a calculable if not demonstrable impact on cost
of ownership . . . but better the owner curses designers, suppliers
and mechanics in the maintenance hangar than while airborne.
I have to laugh when I read some of the "approved" runaway trim
procedures in various operating manuals. The often ignored fundamental
requirement for comfortable outcome of the event is: "Perceive, interpret,
refer to procedure, run the troubleshooting matrix and ultimately find
and pull a breaker . . . in four seconds or less."
A/p and pitch trim runaway qualification requirements for the last
program I worked called for a pilot to put hands in lap, test engineer
generates a simulated runaway, pilot WAITS three seconds minimum before
moving to mitigate the situation. When order is restored, the airplane
shall not have departed from stable flight conditions by specified
maximums."
I'm aware of ONLY two ways to make this work within the 3-second window.
(1) automatic failure sensing and control - VERY expensive and level
A software or (2) slow the motors down such that the 3-second delay
+ action time to hit the wheel master disconnect produces a scenario
acceptable to everyone involved. If anyone has another, simpler and/or
more elegant idea, I'd be pleased to know of it and so would my customers!
