Engine Mount Alignment
tcmoses(at)earthlink.net
PostPosted: Mon Oct 01, 2007 2:38 pm    Post subject: Engine Mount Alignment Reply with quote
Has any one had a problem getting the engine mount level relative to the leveled fuselage (per the assembly instructions)? I currently have about 3.5 degrees of down thrust. If I shorten the upper mount supports, I am bending the lower engine rubber mounts quite a bit. Could the mount be bent from a hard landing? I did not build this plane.
hgmckay
PostPosted: Mon Oct 01, 2007 3:54 pm    Post subject: Engine Mount Alignment Reply with quote
Tim: I built my Allegro 2000 new from a Q-B Kit so I can’t help you on this one. Maybe some other guys on the List can. Sorry!
<![if !supportEmptyParas]> <![endif]>
Hugh McKay
Allegro 2000
Rotax 912 UL
N661WW
-----Original Message-----
From: owner-allegro-list-server(at)matronics.com [mailto:owner-allegro-list-server(at)matronics.com]On Behalf Of TIM MOSES
Sent: Monday, October 01, 2007 6:35 PM
To: allegro-list(at)matronics.com
Subject: Engine Mount Alignment
Has any one had a problem getting the engine mount level relative to the leveled fuselage (per the assembly instructions)? I currently have about 3.5 degrees of down thrust. If I shorten the upper mount supports, I am bending the lower engine rubber mounts quite a bit. Could the mount be bent from a hard landing? I did not build this plane. [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Allegro-List Email Forum - --> http://www.matronics.com/Navigator?Allegro-List � - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
