jindoguy(at)gmail.com Guest
Posted: Sat Oct 06, 2007 6:27 pm Post subject: 582 stater plate any one ?? |
Malcolm, while you're at it get a copy of the heavy maintenance manual and go through the CDI's, too. It would be a real bummer to buy a new stator and find out you had an ignition defect takes out the new one, too.
Rick
On 10/6/07, Malcolmbru(at)aol.com (Malcolmbru(at)aol.com) <Malcolmbru(at)aol.com (Malcolmbru(at)aol.com)> wrote: | Quote: | today I burned out my charging coil , 76 hrs ago I lost the tack coil so I ran a tiny tack. the first thing I noticed was a drop in my charging volts just a little low , then it dropped way off after about 3 hrs flying time when I used my strobe and lights, after inspecting the charging wires i found a burnt wire and only 9 oms on my charging circuit. $600 and 4 hrs labor and i will be back in the air. malcolm kit fox michigan
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
