Dennis.Kirby(at)kirtland. Guest
Posted: Thu Oct 04, 2007 7:15 am Post subject: Rotax 912 Torque Spec Error |
Fellow 912 Drivers -
I discovered an error in the official Rotax manuals that specify the
torque value for the lock-nuts that secure the exhaust system. These
are the copper M8 lock-nuts - two at each exhaust port.
The Rotax 912 Installation Manual (sec 10.1) clearly states that these
nuts should be torqued to 177 inch-pounds. While doing maintenance
today, I was reinstalling the exhaust system on my 912ul, and tightened
these lock-nuts to the specified value.
Afterward, I noticed that the two studs were distorted - they were no
longer pointed straight out of the cylinder head, but skewed a bit from
being overtightened.
I called Lockwood, and the tech guy there looked up the torque value
from the Rotax 912 Illustrated Parts Manual. The number listed there
was 105 ft-lb. I had WAY overtightened those nuts! Looks like I'll be
ordering a pair of new exhaust studs. Fortunately, this was a cheap
lesson for me - they cost only $3.50 each. But it mad me mad that, in
my attempt to do the right thing, the Rotax manual provided wrong
information.
So the lessons here worth passing on to you all are: 1) The torque value
for the exhaust system nuts listed in the Installation Manual is WRONG,
and 2) Refer to the Illustrated Parts Manual for all torques for your
Rotax engine.
I hope this helps someone avoid the mistake I made. Happy flying ...
Dennis Kirby
Mark-III Classic, 912ul, in
Cedar Crest, NM
jenelson1(at)hotmail.com Guest
Posted: Thu Oct 04, 2007 7:45 am Post subject: Rotax 912 Torque Spec Error |
177 inch pounds is only 14.74 Ft-lbs was it listed in the book as In-lbs or Ft-lbs?
| Quote: | Subject: Rotax 912 Torque Spec Error
Date: Thu, 4 Oct 2007 09:07:48 -0600
--> Kolb-List message posted by: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
information.
Rotax engine.
Dennis Kirby
Cedar C-===================================
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote][b]
JetPilot
jindoguy(at)gmail.com Guest
Posted: Thu Oct 04, 2007 7:06 pm Post subject: Rotax 912 Torque Spec Error |
Dennis, Second biggest thing stressed by Eric, was always check that you have the latest version of the manual. R.O.A.N. sent out a notice in late July that all 912 installation manuals had been superceded.
"Rotax has announced the REPLACEMENT of the following 912 Series Installation manuals:
- Installation Manual Rotax 912 A, Edition 0, Rev 2
- Installation Manual Rotax 912 F, Edition 0, Rev 3
- Installation Manual Rotax 912 S, Edition 0, Rev 2
- Installation Manual Rotax 912 UL, Edition 2, Rev 2
These manuals ARE NO LONGER VALID and have been REPLACED by:
- Installation Manual Rotax 912 Series, May 01/2007, Edition 1, Rev0. (Rotax Part No. 898642)"
I downloaded the new installation manual and it gives the same spec as the old one, 12 to 20 Nm (106-177in lb) and both refer to SI-05-97, the relevant part, I believe is:
"It should be noted that this is maximum torque value, and in all cases flange nuts
should never be torqued such that the exhaust flange makes contact with the cylinder
head. If necessary a lesser torque value may be used down to a minimum value of
12 Nm (110 in.lb.) Maintenance personnel should always insure that the exhaust
flange nuts are tightened to the maximum torque possible, not exceeding 20 Nm (180
in.lb.), while still respecting the need for clearance between the flange and the
cylinder head."
Hope this helps.
Rick
On 10/4/07, Jeff Nelson <jenelson1(at)hotmail.com (jenelson1(at)hotmail.com)> wrote:[quote] 177 inch pounds is only 14.74 Ft-lbs was it listed in the book as In-lbs or Ft-lbs?
From: Dennis.Kirby(at)kirtland.af.mil (Dennis.Kirby(at)kirtland.af.mil)
--> Kolb-List message posted by: "Kirby Dennis Contr MDA/AL" <Dennis.Kirby(at)kirtland.af.mil (Dennis.Kirby(at)kirtland.af.mil)>
information.
Rotax engine.
Dennis Kirby
| Quote: | Cedar C-===================================
Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! [quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
Roger Lee
Posted: Thu Oct 04, 2007 9:26 pm Post subject: Re: Rotax 912 Torque Spec Error |
These things can happen, but I would encourage everyone to download the most current manuals on line and sign up for automatic notification of manual changes through ROAN. The torque values of a number of nuts and bolts were changed a while back in a manual revision.
There is a new Heavy maint. and Installation manual out.
There is a new SB out as of today.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Fri Oct 05, 2007 5:44 am Post subject: Rotax 912 Torque Spec Error |
While we are on the torque value topic, the Warp Drive spec for
those little 1/4" hub bolts
(4 per blade on the HP) is 120 in lbs. Three years ago, while
assembling mine, one of those
"genyoowine" aircraft nuts stripped out while attaining that value.
-Made me feel a little creepy as you might understand. OK, maybe
that was a defective
nut but still that is a lot of stress for such a small diameter. -
teensy threads too.
I now use 110 in lbs and retorque after either a good ground runup or
a short test hop.
BB
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Fri Oct 05, 2007 6:42 am Post subject: Rotax 912 Torque Spec Error |
Hey Bob, I noticed that if I loosened the 6 main prop bolts on Warps HPL
hub it
put tremendous presure on the smaller inside bolts.
Maybe I should be replacing mine, although I doubt anything would happen
even if all those smaller blade bolts fell out.
Vic
_________________ MKIIIX040
912UL |
Posted: Fri Oct 05, 2007 6:51 am Post subject: Rotax 912 Torque Spec Error |
Bob, Interesting, the 8mm bolts on my Powerfin are torqued to 175 in.lb. into the steel prop flange and into the aluminum body of the prop hub per the instructions that come with the prop.
Rick
On 10/5/07, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote: [quote]--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
teensy threads too.
neilsenrm(at)comcast.net Guest
Posted: Fri Oct 05, 2007 8:09 am Post subject: Rotax 912 Torque Spec Error |
Robert
The friction pressure of a prop bolted against prop hub is the primary way that torque is transfered to the prop. If you reduce the recommended torque on the bolts the prop bolts could break in shear and the prop might come off. I had a wood prop on a Weedhopper that would shrink and expand depending on the weather. One day it got loose and sheared to prop bolts clean off. Later I was told that wood props need to be retorqued with each change of season or sooner.
Richard Girard is right about the 8mm bolts on the Powerfin. I use some long grade 5, 5/16 bolts that have a higher torque rating than the recommended 175 in lb or 20 nm but I torque to the prop makers recomendation. I asked Stuart about using the bolts higher rating once and got my ass chewed just for asking.
Rick Neilsen
Redrive VW powered MKIIIC
Rick
On 10/5/07, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote: | Quote: | --> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
teensy threads too.
when you live at the airport. |
MKIIIX040
Posted: Fri Oct 05, 2007 9:01 am Post subject: Rotax 912 Torque Spec Error |
Robert isn't talking about the main prop bolts.
Vic do not archive
912UL |
Steve Boetto
Posted: Fri Oct 05, 2007 9:51 am Post subject: Rotax 912 Torque Spec Error |
In a message dated 10/5/2007 12:10:47 P.M. Eastern Standard Time, neilsenrm(at)comcast.net writes:
| Quote: | | The friction pressure of a prop bolted against prop hub is the primary way that torque is transfered to the prop. If you reduce the recommended torque on the bolts the prop bolts could break in shear |
Rick,
You are right about the friction, but I believe what fails the bolts is fatigue from the bolts slightly bending.
Never had any trouble with my Sensenich 64x79 here in Fla where we have big changes in temp and humidity. I did however check the torque monthly. After the first year it seemed to stabilize.
Steve
Firefly 007/Floats
See what's t="_blank">Make AOL Your Homepage.
Posted: Fri Oct 05, 2007 1:49 pm Post subject: Rotax 912 Torque Spec Error |
Steve, I think you and Rick N. are both right, just looking at it from different ways. The prop gets loose as the wood shrinks and the torque pulses of the engine then rock the prop back and forth against the loosened bolts. Eventually, the prop bolts fail in shear.
Rick
On 10/5/07, N27SB(at)aol.com (N27SB(at)aol.com) <N27SB(at)aol.com (N27SB(at)aol.com)> wrote:[quote] In a message dated 10/5/2007 12:10:47 P.M. Eastern Standard Time, neilsenrm(at)comcast.net (neilsenrm(at)comcast.net) writes:
Rick,
Steve
Firefly 007/Floats
Posted: Fri Oct 05, 2007 4:14 pm Post subject: Rotax 912 Torque Spec Error |
Rick G:
Works a little different if your system uses drive lugs, like the Warp Drive.
I very seldom break a prop bolt. One or two since I started flying 912 series engines some time ago.
Question: Would failure in shear and bending be the same? Seems to me shearing off 6 prop bolts would be tough to do with a wooden prop. Bend them enough cycles and they will fail.
[quote]The prop gets loose as the wood shrinks and the torque pulses of the engine then rock the prop back and forth against the loosened bolts. Eventually, the prop bolts fail in shear.
Rick
_________________ John Hauck
Titus, Alabama |
Posted: Fri Oct 05, 2007 7:46 pm Post subject: Rotax 912 Torque Spec Error |
John, Go to Canard Aviators at yahoo groups and read Marc Zeitlin's story. Lyc O-360's have drive lugs and 3/8" bolts to hold on the prop. Look at the pictures of what the prop did to the wing and winglet when it departed. It's a chicken and egg question when you find yourself with a prop one moment and without one the next.
Rick
On 10/5/07, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:[quote] Rick G:
| Quote: | The prop gets loose as the wood shrinks and the torque pulses of the engine then rock the prop back and forth against the loosened bolts. Eventually, the prop bolts fail in shear.
Rick
Posted: Fri Oct 05, 2007 8:13 pm Post subject: Rotax 912 Torque Spec Error |
Rick G:
Thank goodness we have no encountered prop seperation problems with 912 series engines, that I am aware of.
Does an 0-360 have any kind of torsional vibration dampening, other than the prop?
Lyc O-360's have drive lugs and 3/8" bolts to hold on the prop. next.
Rick
Titus, Alabama |
Posted: Fri Oct 05, 2007 9:07 pm Post subject: Rotax 912 Torque Spec Error |
No, theres a flywheel to carry a ring gear for the starter and that adds very little since it's aluminum. Rotax has the benefit of 40 years of engineering science to make their little jewel work. I didn't really appreciate what their engineers had accomplished until I tool Eric's class. Lyc is stuck making adaptations to the technologies of the 1930's. Like the Rotax, it's a real testiment to the engineering technology of its day.
Rick
Rick
Posted: Sat Oct 06, 2007 5:32 pm Post subject: Rotax 912 Torque Spec Error |
John Hauck wrote:
| Quote: | Rick G:
the prop?
<Insert looong howl of laughter here.>
No. It is, after all, a certified engine with all the shortcomings that
implies.
I hope y'all don't mind input from a non-Kolb flier.
I'm building an RV-7. Because of how rough Lyc's typically are, I
debated for a couple of years about using an alternative engine before
giving in to the time saving factor of doing a standard Lyc
installation. Any 4 cyl 4-stoke engine has strong torque reversals
between each power pulse. The only hint of damping in a Lyc is on *some*
of the -360's, that have a 'G' in the suffix letters. Even those don't
have anything between the crank & the prop; they have little pivoting
weights attached to the counterweights on the crank.
The idea that friction between the back of a wood prop & the metal prop
flange keeps the prop from moving is common among pilots of larger
planes, too, but it just doesn't pass a sanity check in all but the very
lowest power situations. In every 'normal' a/c prop installation I'm
aware of, the drive lugs are what transfer the rotational energy from
the prop flange to the prop. (That's why they are called 'drive lugs' )
All the bolts do is keep the prop from 'rocking' in and out of the plane
of the flange. If the prop bolts get loose, motion of the a/c, torque
pulses & reversals will cause the prop to 'rock' on the flange,
wallowing out the close-tolerance holes where the drive lugs fit. Now
the prop is both rocking, bending the bolts (as John mentioned earlier)
and getting it's lug-holes hammered out bigger and bigger by each pulse.
Things feed on themselves & the bolts soon fail.
Want evidence that it ain't friction that keeps blades stable? Ask IVO
about their props for 4 cyl Lycs (if they have started selling them
again). There are no drive lugs in an IVO hub, and the bolt holes in the
blades are way over-sized for the bolt diameter. I've flown 2 different
IVO's on a 160 hp O-320. Both had blade movement. The installation
requirements were to place 'witness tape' (1st copper, then stainless
adhesive backed tape) across the gap between blades and check the tape
*before and after every flight*. The tapes broke on every flight. Note
that the 1st prop I tried had the original hub that IVO sold for Lycs,
with smooth surfaces on the hub plates facing the blade roots. The 2nd
had deeply knurled surfaces, to bite into the blade roots. The 2nd just
chewed up the top layer of glass/resin on the blade root. Both props
were installed to IVO's instructions, using a torque wrench. Eventually,
IVO quit selling props to Lyc owners because they couldn't solve the
problem. (Drive lugs would have stabilized the blades.)
Charlie
Posted: Sat Oct 06, 2007 5:52 pm Post subject: Rotax 912 Torque Spec Error |
| Quote: | IVO quit selling props to Lyc owners because they couldn't solve the
Charlie
Charlie:
Probably stabalize the blades long enough for the drive lugs to eat the IVO
hub.
Titus, Alabama |
Posted: Sat Oct 06, 2007 6:03 pm Post subject: Rotax 912 Torque Spec Error |
Charlie, I almost mentioned the Ivo Lycoming mismatch, but I have only the experience of others to go by.
Ivo has added drive lug counterbores to the hubs of their bigger props, at least the one that came with my trike had them. I sent it back after reading the installation instructions.
The instructions were, and I only wish I were making this up:
Torque to spec, run engine for one minute. Torque to spec, run engine two minutes. Torque to spec, run engine four minutes. Torque to spec, and so on, and so on. I added it all up and it came to over eight hours before you could do anything like a normal flight. Then read the tape and retorque every two hours, replacing the tape after each new torque job. Sheesh.
As I told the owner of the trike co., "How am I supposed to explain to a customer that installation is going to cost as much as the prop, not to mention the cost of sleeping pills should I ever turn one over to a customer."
I just do not like the idea of prop blades that are held into the hub by bolts alone, although I have to admit, as a life long machinist, I was fascinated by the 60 degree flat knurling on each side of the hub plates. A real testimony to what can be done with CNC machines.
But when it comes to props, I like the robust blades of the Warp and the light weight of the Powerfin. Now if I could just have both qualities in the same prop. Oh, well, a happy life is knowing where to set your standards and where to compromise.
RIck
On 10/6/07, Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)> wrote:[quote] --> Kolb-List message posted by: Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)>
John Hauck wrote:
| Quote: | Rick G:
the prop?
implies.
