		d-m-hague(at)comcast.net Guest
				 Posted: Sat Oct 06, 2007 6:27 pm    Post subject: trim tab attachment |
				OK, after the 5th flight in my US I've decided I need to add an elevator
 trim tab.  It takes constant back pressure to hold it level at any power
 setting, not much force but let go and it dives at an alarming rate.  I
 thought of using a bungee but I like the idea of a tab better as it's fail
 safe if anything fails in the elevator linkage.  Or I may set the trim tab
 to a survivable glide speed and also add a bungee trim for fine adjustment.
 Anyway, what is the best way to mount it?  I assume riveting it on, to the
 lower surface of the elevator, but I don't want to weaken anything.  Do I
 rivet it to the trailing edge tube, or the ribs, or both?
 				-Dana
 "I'm a lawyer." "Honest?" "No, the usual kind."
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sat Oct 06, 2007 6:45 pm    Post subject: trim tab attachment |
 the
  	  | Quote: | 	 		   lower surface of the elevator, but I don't want to weaken anything.  Do I
  -Dana
 Dana:
 If it was my problem, first I would insure those big ole barn door ailerons
 are rigged correctly in flight, not necessarily sitting still on the ground.
 If they are drooped a tad, the aircraft will want to pitch down.
 The US low thrust line in pusher configuration should encourage the US to
 climb under power.
  _________________ John Hauck
Titus, Alabama |
				 Posted: Sat Oct 06, 2007 6:59 pm    Post subject: trim tab attachment |
				At 10:45 PM 10/6/2007, John Hauck wrote:
 ailerons are rigged correctly in flight, not necessarily sitting still on
 the ground.
 Thanks John, that was one of the things I checked today.  On the ground,
 they're dead even with the wing (wing lower surface to aileron lower
 surface).  In flight, if anything they ride a bit higher.  I considered
 reflexing them a bit and I still might try that, but I don't want to raise
 the stall speed.
 I also considered that the plane might be nose heavy, but I have plenty of
 elevator authority through stall and/or flare, and as near as I can tell
 the elevators are even with the stabilizer when I'm holding the back
 pressure required for level flight.
                                  -Dana
                                  -Dana
				 Posted: Sat Oct 06, 2007 7:12 pm    Post subject: trim tab attachment |
 of
  	  | Quote: | 	 		   elevator authority through stall and/or flare, and as near as I can tell
                                  -Dana
 Wing incidence may not be correct.  Too much or too little, I do not know
 how that would affect pitch attitude.
 On my US, I rigged it according to the construction manual.  It still needed
 rudder, aileron, and elevator trim tabs to zero out any adverse pressure on
 the stick.  I made all the tabs out of .016" alum.  They were easy to bend
 for adjustment.  I also believe they were relieved of some of their angle of
 attack as airspeed increased.  My FS was rigged identically.  Trimmed out
 perfect with the same three trim tabs.
Titus, Alabama |
				 Posted: Sun Oct 07, 2007 4:43 am    Post subject: trim tab attachment |
				At 11:11 PM 10/6/2007, John Hauck wrote:
  	  | Quote: | 	 		  Wing incidence may not be correct.  Too much or too little, I do not know
 Insufficient wing incidence (or more correctly, insufficient declage, which
 is the relative angle between wing and stabilizer) would cause a nose down
 tendency.  I don't think that's the case, though.
  	  | Quote: | 	 		  On my US, I rigged it according to the construction manual.  It still
 needed rudder, aileron, and elevator trim tabs to zero out any adverse
 pressure on the stick.  I made all the tabs out of .016" alum.  They were
 easy to bend...
 How did you attach them?  Rivets I assume, but into what?  The trailing
 edge or ribs or both?
                                  -Dana
				 Posted: Sun Oct 07, 2007 5:26 am    Post subject: trim tab attachment |
  	  | Quote: | 	 		   edge or ribs or both?
                                  -Dana
 Back then, I attached to trailing edge with 1/8" fabric rivets, about 1"
 spacing.
 If you put enough hours on the aircraft you will probably have to replace a
 trim tab or a rivet or two.
 On the mkIII I attach the only trim tab to the rudder using two ribs and no
 rivets in the trailing edge.
Titus, Alabama |
