jindoguy(at)gmail.com Guest
				 Posted: Sat Oct 06, 2007 6:27 pm    Post subject: 582 stater plate any one ?? |
				Malcolm, while you're at it get a copy of the heavy maintenance manual and go through the CDI's, too. It would be a real bummer to buy a new stator and find out you had an ignition defect takes out the new one, too.
 Rick
 On 10/6/07, Malcolmbru(at)aol.com (Malcolmbru(at)aol.com) <Malcolmbru(at)aol.com (Malcolmbru(at)aol.com)> wrote:  	  | Quote: | 	 		           today I burned out my charging coil , 76 hrs ago I lost the tack  coil so I ran a tiny tack.   the first thing I noticed was a drop in  my charging volts just a little low , then it dropped way off after about 3  hrs flying time when I used my strobe and lights,   after inspecting the  charging wires i found a burnt wire and only 9 oms on my charging circuit.   $600  and 4 hrs  labor and i will be back in the  air.    malcolm   kit fox  michigan
 Rick Girard
 "Ya'll drop on in"
 takes on a whole new meaning
 when you live at the airport.  [quote][b]
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
