		HBaker
				 Posted: Sun Feb 08, 2009 5:56 am    Post subject: Air start |
				I' m hooking up the air start an was wondering about the water trap and the solonoids Is there three of these , one on the air start, one on the Isolaion valve and one on the water trap, are you hooking up the water trap with some kind of a colection ,loop or container before the valve? And  2 of the the valves are normally closed and one open?
  |  | - The Matronics M14PEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?M14PEngines-List |
  _________________ Currently building a Murphy Moose - any help would be appreciated. |
		george(at)gesoco.com Guest
				 Posted: Sun Feb 08, 2009 6:27 am    Post subject: Air start |
				Usually you exit the air compressor with some steel line. Put a loop or two
 in it for vibration isolation and some cooling to condense the water and oil
 vapors. It then goes to the water trap. From the water trap it usually goes
 to the air system through a check valve. The pressure bottle is usually
 isolated with a manual valve so you do not loose pressure while the aircraft
 is parked. The start valve is hooked to the system and is either
 electrically or mechanically activated. The electrical valves can have some
 problems as they sometimes gum up with the oil residues that are in the air
 system. Many of the eastern aircraft used a mechanical valve. This had the
 advantage that once thrown it left both hands free to work throttle, primer
 magi switches etc.
 If you go to the instillation section of the M14P engines on our website at
 motorstarna.com  you will see a sample system schematic. There may also be
 some other useful information there as well.
 George Coy
 Motorstar NA
 714 Airport Rd.
 Swanton VT 05488
 802-868-5633 off
 802-363-5782 cell
 george.coy(at)gmail.com
 SKYPE george.coy
 motorstarna.com
		yakplt(at)yahoo.com Guest
				 Posted: Sun Feb 08, 2009 1:59 pm    Post subject: Air start |
				A comment on design if I may.  The original Yak design used a steel line with loops in it as George described.  With later models, they used a steel line, a few loops and then a steel braided line connected to the end of it which then connected to the water trap.  <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
 Sukhoi designs simply used a braided high pressure steel line and never bothered with the hard steel line (loops or no loops).
 My YAK-50, plus two YAK-52’s that I know about have had problems when using a solid steel line, with the loops, connecting straight to the water trap (snot valve).  The reason is fairly obvious.  The engine moves in it’s shock mounts (rubbers).  The snot valve is connected to the firewall.  As the engine vibrates, this steel line has to flex and move with it.  Over time, it is going to fail.
 Bottom line, in my humble opinion, lose the steel line and replace it with a steel braided flex line.  Or…use the steel line, but have a piece of braided flexible line between the steel line and the snot valve.  On mine I managed to get the
 There are two models of start valves.  One has manual capability, one does not.  If you can find an old one that does not work, you can take the new model and steal the parts out of it to repair an old one so you do have manual capability, which is a very good thing to have as George points out.
 Mark Bitterlich
 To: m14pengines-list(at)matronics.com
 Sent: Sunday, February 8, 2009 9:25:58 AM
 Subject: RE: M14PEngines-List: Air start
 --> M14PEngines-List message posted by: "George Coy" <george(at)gesoco.com (george(at)gesoco.com)>
 magi switches etc.
 George Coy
 Motorstar NA
 714 Airport Rd.
 Swanton VT 05488
 802-868-5633 off
 802-363-5782 cell
 george.coy(at)gmail.com (george.coy(at)gmail.com)
 SKYPE george.coy
 motorstarna.com
