F-904H Center Section Side Plate
brown_rj(at)bellsouth.net
PostPosted: Sat Feb 18, 2006 10:55 am    Post subject: F-904H Center Section Side Plate Reply with quote
I think my right 904H might have been drilled backward. It appears on dwg 23 coordinates 3.5, and C, that the top of the spar flange has a bevel on the front flange. The 904H has this same bevel. My left side matches the dwg, but the right has the bevel on the aft flange of the spar. I matched up the bevels not paying attention to the orientation and matched drilled. Now I notice the spacer will not come out of the slot between the two spars. If I flip the 904H over, the slot works fine, and all is well. The issue now is the hole spacing. the front is supposed to have 24 holes and the rear flange 25 according to dwg 16. I can't simply drill new holes as they will elongate the current ones, any ideas, thoughts? The left side is correct.. spar flange serial numbers and orientation marks from vans is correct..
