		Malcolmbru(at)aol.com Guest
				 Posted: Sat Oct 06, 2007 7:10 pm    Post subject: 582 stater plate any one ?? rick |
				good idea what do you mean? by heavy maintenance manual ?    malcolm
 See what's new at ww.aol.com?NCID=AOLCMP00300000001170" target="_blank">AOL.com and
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jindoguy(at)gmail.com Guest
				 Posted: Sun Oct 07, 2007 4:44 am    Post subject: 582 stater plate any one ?? rick |
				Malcolm, There are four manuals for the Rotax two strokes, Installation, Operation, Line Maintenance (although it's called the maintenance manual), and Heavy Maintenance. The Heavy Maintenance Manual is for Models 462, 532, and 582. It is part no. 899 081 The section you want to look at is  7.9 starting on page 59.
 At the Rotax aircraft engine site it's listed as the Repair manual, the part number is the same but it's shown as n.a. under file and pdf file size.
  http://www.rotax-aircraft-engines.com/a_searchdoc.aspx
 I got mine at the repair center classes at Lockwood. I'll see if I can get my scanner up and running (even finding it may be a miracle after three moves, so I make no promises) and send the relevant pages.
 Any body out there have this manual and a working scanner?
 Rick
 On 10/6/07, Malcolmbru(at)aol.com (Malcolmbru(at)aol.com) < Malcolmbru(at)aol.com (Malcolmbru(at)aol.com)> wrote:
 Rick Girard
 "Ya'll drop on in"
 takes on a whole new meaning
 when you live at the airport.  [quote][b]
				 Posted: Sun Oct 07, 2007 5:25 pm    Post subject: 582 stater plate any one ?? rick |
				I have taken that course 3 times.  I have that book and used it to get  my specs on lighting coil oam limits  mine are low only  .9  and  seems to be over charging the system.    I smoked a wire at the  connection re hooked it up and am charging at almost  14.75  volts   I will double check everything with the help of live support  from Brett from LEAF.      I also try to keep good records  by writing everything down so I give the info out properly.  it is only  airplane money.   what is moor valuable is the Waite and balance I  need to keep with the wife. 3 hrs at the airport regardless of what i am  doing  costs  me 6 hrs maintained  at home     malcolm
				 Posted: Sun Oct 07, 2007 8:02 pm    Post subject: 582 stater plate any one ?? rick |
				Oh good. I picked up some kind of bug for my birthday and have just felt like crud all day long. Was afraid if I went down stairs to look for the scanner, I'd have just had to move down there.Did get a good start on the EAA chapters November newsletter, though. Gotta get well, good flying weather coming Tuesday according to the guessers.
 Rick
 On 10/7/07, Malcolmbru(at)aol.com (Malcolmbru(at)aol.com) <Malcolmbru(at)aol.com (Malcolmbru(at)aol.com)> wrote: [quote]     I have taken that course 3 times.  I have that book and used it to get  my specs on lighting coil oam limits  mine are low only  .9  anod  seems to be over charging the system.    I smoked a wire at the  connection re hooked it up and am charging at almost  14.75  volts   I will double check everything with the help of live support  from Brett from LEAF.      I also try to keep good records  by writing everything down so I give the info out properly.  it is only  airplane money.   what is moor valuable is the Waite and balance I  need to keep with the wife. 3 hrs at the airport regardless of what i am  doing  costs  me 6 hrs maintained  at home     malcolm
    [quote][b]   http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Mon Oct 08, 2007 12:04 pm    Post subject: Re: 582 stater plate any one ?? rick |
				Here is a link to check out with manuals online for a good number of engines:
 Check the Advisories as well to see that you are up to date:
  http://www.ultralightnews.ca/rotax582
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
