Cat36Fly(at)aol.com Guest
Posted: Thu Jan 05, 2006 6:50 am Post subject: Key West Tach Signal |
Has anyone got a trick for getting a reliable tachometer signal from a Key
West Regulator ? I am using the lighting coil signal (Rotax 582) to drive an
analog tach but want to use the one on my ESI also. Kuntzleman believes it can
be done but Grand Rapids Technologies says I need a different rectifier
(Tympanium 3 phase). Any past experience here?
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
rowedl(at)highstream.net Guest
Posted: Thu Jan 05, 2006 8:56 pm Post subject: Key West Tach Signal |
Posted: Fri Jan 06, 2006 5:04 am Post subject: Key West Tach Signal |
Denny,
gtalexander(at)att.net Guest
Posted: Fri Jan 06, 2006 5:49 am Post subject: Key West Tach Signal |
Larry:
Maybe someone with vast electronic expertise can answer this, but I'm not sure how you could get ANY tachometer to function on the OUTPUT of ANY rectifier. I thought a tach reacts to interrupted or alternating conditions (current) and a rectifier puts out uninterrupted current flow. Dick K? Jack H? I'm so confused.
George Alexander
http://gtalexander.home.att.net
Posted: Fri Jan 06, 2006 6:05 am Post subject: Key West Tach Signal |
George,
snuffy(at)usol.com Guest
Posted: Fri Jan 06, 2006 6:25 am Post subject: Key West Tach Signal |
. I thought a tach
puts out
The output of a rectifier alone is a pulsing DC signal. When capacitors
and other types of filters are added it becomes a smooth dc signal.
Frequency and amplitude are the main concerns when feeding it into a
tach.
Do not
archive
jbhart(at)onlyinternet.ne Guest
Posted: Fri Jan 06, 2006 8:12 am Post subject: Key West Tach Signal |
At 01:49 PM 1/6/06 +0000, you wrote:
Larry:
George Alexander
George,
I can't help unconfuse you. I gave up and mounted a tinytach.
Jack B. Hart FF004
Winchester, IN
