acs(at)acspropeller.com.a Guest
Posted: Tue Oct 09, 2007 12:16 pm Post subject: Aileron deflection |
Can someone please tell me ( I need approximate only) what is the measurement between the wingtip trailing edge and the aileron trailing edge when it is fully deflected upwards after complete assembly of control linkages? Is it 1", 2" or so?
John 40315
wvu(at)ameritel.net Guest
Posted: Tue Oct 09, 2007 7:42 pm Post subject: Aileron deflection |
John,
This is from memory... Seems about 3" up, 1.5" down.
Anh
N591VU-flying
Posted: Tue Oct 09, 2007 10:20 pm Post subject: Aileron deflection |
Thanks Anh, I’m just trying to eyeball the setup to make sure it looks right and check the clearances.
John 40315
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu
Sent: Wednesday, 10 October 2007 1:45 PM
Subject: Re: Aileron deflection
John,
Anh
N591VU-flying
LloydDR(at)wernerco.com Guest
Posted: Wed Oct 10, 2007 5:08 am Post subject: Aileron deflection |
There is also a table of min/max travels in the first few chapters of the construction manual, you know the ones that also tell you how to do your weight and balance, and test flights? I do not remember the chapter number, but the FAA inspector wanted to see this table and then measure travel on the control surfaces to make sure they met but did not exceed the recommended values.
Dan
N289DT RV10E Flying
Sent: Tuesday, October 09, 2007 11:45 PM
John,
Anh
N591VU-flying
Posted: Wed Oct 10, 2007 12:25 pm Post subject: Aileron deflection |
Thanks Dan, I'll look this up. I was just curious as to what looks normal in the total deflection, up versus down and also what this translated to, given aileron rod clearances as has been discussed numerous times. I'm trying to determine if/when requiring maximum control deflection, what is the chances of any foulups and any possibility of ending up over centre on the auto pilot servo linkage. Also what this means to the control stick clearances in the cockpit.
John 40315
