Mike Whisky
Posted: Sat Oct 13, 2007 8:03 am Post subject: Why to use Vans fuel filter when using Andair gascolator? |
Hi,
I want to use the Andair Gascolator (GAS375) and wonder if the Vans fuel filter is still required.
How many times do you need to have access to the tunnel? If I want to go with a center console the access will be rather difficult.
Best regards
Michael
www.wellenzohn.net
_________________ RV-10 builder (flying)
#511 |
GenGrumpy(at)aol.com Guest
Posted: Sat Oct 13, 2007 8:39 am Post subject: Why to use Vans fuel filter when using Andair gascolator? |
My opinion.
YES. Keep the filter (I have gascolator also....).
Make whatever you do on the tunnel easy to remove.....you'll be in there more than you think.
grumpy
N184JM Down for Paint
DO NOT ARCHIVE
In a message dated 10/13/2007 11:06:18 A.M. Central Standard Time, rv-10(at)wellenzohn.net writes:
| Quote: | --> RV10-List message posted by: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Hi,
Best regards
Michael
www.wellenzohn.net |
See what's new [quote][b]
Deems Davis
Mike Whisky
Posted: Sat Oct 13, 2007 9:22 am Post subject: Re: Why to use Vans fuel filter when using Andair gascolator |
Does the tunnel have no structural role at all?
Cutting access holes will not make it stronger. And I believe I'd have to show this a major modification from the original plans to the authorities.
Michael
#511 |
