Aileron Pushrod F-1064 Length
rvreynolds(at)macs.net
PostPosted: Sat Feb 18, 2006 4:47 pm    Post subject: Aileron Pushrod F-1064 Length Reply with quote
RV-10/39-5 dwg shows F-1064 length of 12 5/8 in.
The material is furnished 13 1/8 in. Which length is correct?
Also is there a change in the length of the Pushrod Sleeve F-1064B
(1/2 in) ?
Richard Reynolds
RV-10
LarryRosen
PostPosted: Sat Feb 18, 2006 6:19 pm    Post subject: Aileron Pushrod F-1064 Length Reply with quote
In fact I have one that is 12 5/8" and one that is 13 1/8. I called
Vans and they said they were changing the length of the pushrod so you
do not need the sleeves. (I must have been right in the middle of the
switch). Just set the overall length to 14 7/8 center to center from
the rod end bearing.
Larry Rosen
http://lrosen.nerv10.com
(1/2 in) ?
Richard Reynolds
RV-10
Larry Rosen
#40356
N205EN (reserved)
<http>
Tim(at)MyRV10.com
PostPosted: Sat Feb 18, 2006 6:43 pm    Post subject: Aileron Pushrod F-1064 Length Reply with quote
Any idea why they needed the sleeves in the first place? I could
never figure out why they were there. Mine aren't tight or anything.
The nut is tight on the pushrod though.
Larry Rosen
> (1/2 in) ?
> Richard Reynolds
> RV-10
> http://www.matronics.com/Navigator?RV10-List
