		john_graham
  Joined: 09 Aug 2007 Posts: 45 Location: Algonquin, IL
				 Posted: Thu Oct 11, 2007 9:19 am    Post subject: Fuel pump failure |
				If the engine driven fuel pump fails in flight, I have
 heard one can pump the primer lever rapidly to keep
 enough fuel going to the engine to keep it running
 long enough to land the plane.  Is this true?  Also,
 would one pump the handle after turning it to the left
 (fuel pressure) or right (fuel primer)?
 As always, thanks for your answers as I continue to
 learn about my Yak 52.
 John P. Graham
 CubFlyer1940(at)Yahoo.com
 Cell phone  (847) 641-1330
 http://smallbusiness.yahoo.com/webhosting
  _________________ John Graham
N15YK  1993 Yak-52
CubFlyer1940@Yahoo.com
(847) 641-1330 |
		Scooter
				 Posted: Thu Oct 11, 2007 9:47 am    Post subject: Re: Fuel pump failure |
				You might want to get hold of one (or more) of the "flight manuals" floating around on the net.  The version I have has the following:
 Low fuel pressure
 Turn the mechanical fuel pump 45 left and pump to provide fuel pressure then land as soon as possible.
		richard.goode(at)russiana Guest
				 Posted: Thu Oct 11, 2007 9:59 am    Post subject: Fuel pump failure |
				The obvious side is to pump intp the  carburetor and you can keep the engine going indefinitely-or at least until your  hand is totally lacerated!!
  Not so well known is that you can keep the  engine going by priming on the "cylinder" side if the carburetor or the fuel  supply to the carburetor has failed.However it has to be done very carefully to  avoid either drowning or starving the engine!
  Richard
  Richard Goode Aerobatics
 Rhodds Farm
 Lyonshall
 Hereford
 HR5  3LW
 United Kingdom
  Tel:   +44 (0) 1544 340120
 Fax:  +44 (0) 1544  340129
 www.russianaeros.com
  [quote]   ---
		dsavarese(at)elmore.rr.co Guest
				 Posted: Thu Oct 11, 2007 10:23 am    Post subject: Fuel pump failure |
				Yes, Scooter is correct PROVIDED it is LOW fuel pressure.  Low fuel pressure
 means the fuel pump is working somewhat.  NO fuel pressure means you pump
 like heck with the pump to the right because that is the direction that
 pumps fuel into the supercharger and ultimately into the intake tubes and
 cylinders.
 Dennis
				 Posted: Thu Oct 11, 2007 11:12 am    Post subject: Fuel pump failure |
				You guys really think you are going to keep the fire lit pumping like crazy
 and be able to land. Which is the primer handle is turned to the right when
 you have ZERO fuel pressure for the 52 that is. The 50 is to the left for
 cylinder priming. With a totally dead fuel pump pressurizing the system is
 not going to get you anything but a cough.
 I have been down that road on the ground now add flying the airplane with
 your left hand and pumping like crazy with the right! Just hope some
 passerby does not get the wrong idea as that plane bobs up and down like a
 cork! The poor chase ( if there is one) is going to be one sea sick dude not
 to say what you are going to look like coming down final! Guess there is a
 positive though, you are coming down final.
 Like I said I did that once on the ground when the fuel pump we rebuilt was
 reassembled with the rotor in 180 out (yes you can do that). 0 fuel
 pressure. She started and I pumped like "crazy" to keep her going to the
 tune of about a stroke every 2-3 seconds which is about as fast as you can
 pull the plunger out and push it in. Not really sure how long I could have
 keep that up. She will run about 2 seconds before she starts to wind down.
 That was at idle! Wonder how fast you have to pump at 70% and 400 mmHg for
 holding the glide slope on final? I do not know.
 The question is, is it worth crashing an airplane on final or bailing out at
 2500 or so feet?
 If it happened to me and I was not in gliding distance (for the 52 that is
 pretty darned short), I'm taking the silk let down personally!
 Sorry Tom or Cannon, you'll have to buy me a new one if that happens.
 Just my useless 2 c.
 Doc
		craig(at)ustek.com Guest
				 Posted: Thu Oct 11, 2007 11:44 am    Post subject: Fuel pump failure |
				I have an electric boost pump. 28V facet mounted on the firewall, in
 fuel line before the engine driven fuel pump.  Cheap investment  Model
 40164  $42.60 at Aircraft Spruce
 Don't fly without one!
				 Posted: Thu Oct 11, 2007 12:10 pm    Post subject: Fuel pump failure |
				That is a GREAT IDEA that I had not thought of! Not that I have any corner
 on bright ideas. I don't! Especially since I ops tested the yes you can
 reassemble the fuel pump backwards!
 Thanks.
 Doc
		Rob Rowe
  Joined: 10 Jan 2006 Posts: 124 Location: Berkshire, UK
		jimscjs(at)mbay.net Guest
				 Posted: Thu Oct 11, 2007 5:40 pm    Post subject: Fuel pump failure |
				Frank Put one in his Plane also, good Idea, just more Items.
 Jim
		brian-1927(at)lloyd.com Guest
				 Posted: Thu Oct 11, 2007 6:48 pm    Post subject: Fuel pump failure |
				On Oct 11, 2007, at 12:10 PM, Roger Kemp wrote:
  	  | Quote: | 	 		   The question is, is it worth crashing an airplane on final or
  bailing out at
  2500 or so feet?
 Pump to get yourself into the pattern and in position to make the
 runway dead-stick. Quit pumping and dead-stick the airplane onto the
 runway safely. You can do a power-off landing of the airplane, can't
 you?
  	  | Quote: | 	 		   If it happened to me and I was not in gliding distance (for the 52
  that is
 So you wouldn't even try to keep the engine going? I know I would. If
 I couldn't THEN I would make a forced landing (good landing spot) or
 bail out (no good landing spot).
 Brian Lloyd                         3191 Western Drive
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 — Antoine de Saint-Exupéry
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
		cliff(at)gesoco.com Guest
				 Posted: Fri Oct 12, 2007 1:33 pm    Post subject: Fuel pump failure |
				All of the 52TW's have an electric boost pump installed in parallel with
 the "system" side of the primer.
 I'd recommend using a 40194 pump-  It has both a check valve and an
 anti-siphon valve.
 This will prevent any "loopback" through the electric pump.
 'spruce sells the 40194 (although they don't always show it in their
 catalog)
 Cheers,
 Cliff
 Thanks.
 Doc
				 Posted: Fri Oct 12, 2007 2:02 pm    Post subject: Fuel pump failure |
				With a little thought and some minor tubing changes said pump could be
 used to replace the complete primer ... Period.
 The replacement would just have a toggle selector valve (system or
 prime) and an electric switch having "momentary/off/on contacts". This
 would duplicate the exact design used with the BIG radials, and would
 also act as the backup fuel pump.
 Better yet.... Include an electric selector valve in the design.  When
 you push the electric switch to the spring loaded off "momentary"
 position, it primes.  Switch it to the "ON" side and it provides system
 pressure and thus a backup fuel pump.
 Of course, with a total loss of electric power, the engine would then be
 very hard to start.  But then, how many people really need to start with
 a 100% total loss of electrical power?  A few I guess.
 Interesting idea.
 Mark Bitterlich
 N50YK
				 Posted: Sat Oct 13, 2007 7:42 pm    Post subject: Fuel pump failure |
				After giving the matter a couple minutes of thought...
 You could tee a Facet 40194 pump into the supply of the hand primer.
  From the pump a line is plumbed to a Parker Skinner 71335SN2KNJ1
 three-way solenoid valve.
 Each outlet of the three way valve would be tee'd into the respective
 priming line (system or cylinder).
 This should be a parallel but independent system requiring no extra
 check valves. (leaves the manual system operable)
 Power would be supplied by a cole hersee 55094 or Philmore Datak 30-340
 Progressive Toggle Switch (OFF-ON-MOM ON).
 and wired such that in the regular "on" position the pump would
 pressurize the carburetor.
 The "momentary on" position would energize the solenoid valve to divert
 the fuel to the intake manifold.
 This would be a fun project.  Parts would be about $200.
 Cheers,
 Cliff
 Interesting idea.
 Mark Bitterlich
 N50YK
				 Posted: Mon Oct 15, 2007 3:12 pm    Post subject: Fuel pump failure |
				On Oct 15, 2007, at 3:21 PM, Bitterlich, Mark G CIV Det Cherry Point,
 MALS-14 64E wrote:
  Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
  Cliff!  Would you make us a KIT?
 I was already planning to replace the wobble pump and primer in my
 CJ6A with an electric pump anyway. If there was a kit at something
 not to far from the retail parts prices, I would probably pop for one
 too.
				 Posted: Tue Oct 16, 2007 5:08 am    Post subject: Fuel pump failure |
				Sure....how about July 2008?  <grin>
 Seriously, without an airplane in the hangar to do the first one, it'd
 be silly of me to come up with complete system sitting at my computer.
 After the three main components- the pump, the solenoid valve, and the
 switch, it's all hose, tube, and fittings.
 I'd Tee into manifold primer hose as it comes out of the firewall.
 I'd use oil dilution hose for the system prime.
 For safety issues and for ease of installation, I'd tee into the primer
 feed line inside the cockpit and run it through the firewall to the
 pump- mounted on the firewall with the solenoid valve.
 Again this is all seat at the desk.....
 Cheers,
 Cliff
 Mark
				 Posted: Tue Oct 16, 2007 2:36 pm    Post subject: Fuel pump failure |
				Yes, but it is EXPERIENCED "seat at the desk" advice, thus worth a lot!
 Thanks Cliff!
 By the way, good thought on the oil dilution switch.  Many people have
 also used that switch for the after market oil scavaging pump idea.
 Personally, I use it for an "emergency electrical switch".  I would not
 recommend it for others, but I ran a wire right to the "Combined Device"
 relay so I can over-ride all the internal systems and close the main
 contactor relay by hand if I so choose.  Thus if I lose all electrical
 power, and it is something wrong with current sensing, over-voltage,
 under-voltage, you name it... I can close that relay for a split second
 while watching the voltage and current gages and if all looks well, I
 can hold it up manually and charge the battery in an emergency.
 Actually I wired this up after having one of the internal relays in the
 combined device fail in flight leaving me with an operable generator,
 but no way to use it.  I used that switch to over-ride the internal
 systems and connect the generator to the main bus manually.  Of course
 the engine had to be at speed, and I had to carefully monitor voltage
 and current, but it allowed me to get the airplane home.  I just ended
 leaving the wire to do it in place.
 Mark
