antenna stiffeners
leinad
PostPosted: Wed Oct 17, 2007 5:39 pm    Post subject: antenna stiffeners Reply with quote
I just installed the com antenna. I placed the antenna about 8 inches forward of the back of the luggage area on the top skin. This skin is very flimsy at this point. What have others done? My gut says it's too flimsy and should have a stiffener added.
Dan Dempsey
plans building 601XL
Jaybannist(at)cs.com
PostPosted: Wed Oct 17, 2007 5:56 pm    Post subject: antenna stiffeners Reply with quote
Dan,
I added a 5" x 8" x .040 doubler under the skin.
Jay in Dallas 601XL N2630J
Dan Dempsey
http://forums.matronics.com/viewtopic.php?p=140550#140550
craig(at)craigandjean.com
PostPosted: Wed Oct 17, 2007 6:10 pm    Post subject: antenna stiffeners Reply with quote
Did you include the two crimped L angles that arch between the two upper
front-to-rear L stiffeners? See pages 8-10 of this part of the photo
assembly guide:
www.zenithair.com/zodiac/xl/data/6-b-21c.pdf
-- Craig
archerm
PostPosted: Wed Oct 17, 2007 6:44 pm    Post subject: antenna stiffeners Reply with quote
I was not happy with my original location also. I ended up moving it and
putting in a stiffener. You can check it out here.
http://www.zodiacxl.com/Top%20Skin.htm
Good luck
Matt
www.zodiacxl.com
Matt
www.zodiacxl.com
GLJSOJ1
PostPosted: Thu Oct 18, 2007 12:26 am    Post subject: Re: antenna stiffeners Reply with quote
I MOUNTED MY AS FAR AFT IN THE BAGGAGE AREA AND ADDED A .040 PLATE TO IT AND CURVED IT TO MATCH. I ALSO ENDED UP PUTTING A ACCESS DOOR UNDER THE FUSELAGE, AND WITH THAT I WOULD HAVE PUT THE ANTENNAE OVER THAT AND NOT IN THE BAGGAGE AREA. STILL WORKS FINE
GLENN
601XL N676L FLYING PHASE I
CHESAPEAKE VA
leinad
PostPosted: Thu Oct 18, 2007 5:16 pm    Post subject: Re: antenna stiffeners Reply with quote
Craig,
Oops :( Thanks for reminding me. I knew about it at one point. Anyway I think I'll combine the crimped antenna support and a doubler under the skin like some others have done. Thanks for setting me straight.
Luckily it wasn't riveted yet.
Thank you to the others that replied too.
Dan
assembly guide:
-- Craig
