		CJcanuck
				 Posted: Wed Oct 17, 2007 3:50 am    Post subject: Prop seals |
				Hi All!
 Lately I've noticed an increase in the amount of oil seeping out of the prop hub and down the prop blades after each flight.  I've also started to see some splatter on the wings (mainly the left) and the windscreen.  My AME feels it's due to the prop seals 'drying out' due to insufficient flying.
 We are planning on pulling the prop anyways come annual time, but I was wondering if anyone has any other ideas, or ways of keeping the prop seals in good condition during periods of inactivity.
 FYI, the prop came from China with zero-time, though from the look of the paint on the blades it's not a new prop unit, just overhauled.
 Thanks!
		cjpilot710(at)aol.com Guest
				 Posted: Wed Oct 17, 2007 4:41 am    Post subject: Prop seals |
				In a message dated 10/17/2007 7:52:38 A.M. Eastern Daylight Time,  m_kirk69(at)hotmail.com writes:
  First of all fly more often.
  Second, the prop seals are easily changed.  Just make sure you put  them in the correct way.  Make sure there are no scratches.  Smooth  them out with very fine emery paper.
  Third, I don't think the seal "dry out" really.  Because they are not  moving and stationary for a long time, they tend to take a "set" to one  side which allows oil to by pass.  Even if you don't fly, Just running the  engine and cycling the prop a number of times, several time a month, help keep  that from happening.
  Jim "Pappy" Goolsby
   	  | Quote: | 	 		  Hi    All!
 Thanks!
		rvfltd(at)televar.com Guest
				 Posted: Wed Oct 17, 2007 5:33 am    Post subject: Prop seals |
				One thing to keep in mind, the Chinese do not "overhaul" as we here in the US do, they I.R.A.N.  If your prop seals looked good to the fellow doing the work at the "overhaul" shop he may not have thought it was necessary to replace them.
  Inspect, Repair, As Necessary.
  We all need to understand what "overhaul" means in the various countries.
  Always Yakin,
  Doug
  cjpilot710(at)aol.com (cjpilot710(at)aol.com) wrote:
  [quote]            In a message dated 10/17/2007 7:52:38 A.M. Eastern Daylight Time, m_kirk69(at)hotmail.com (m_kirk69(at)hotmail.com) writes:
    Jim "Pappy" Goolsby
     	  | Quote: | 	 		  Hi All!
  Thanks!
		wlannon(at)persona.ca Guest
				 Posted: Wed Oct 17, 2007 8:14 am    Post subject: Prop seals |
				The seals are the "chevron" type and tend to lose their set over time. The
 Chinese ones seem particularly poor in this regard. The Russian ones may be
 better.
 The oil leakage you see coming from the hub is in fact coming through the
 hub from the pitch change unit. The hub is lubricated by grease and has
 blade seals intended to retain the grease. They do not work too well with
 oil.
 You need to replace the two seals on the pitch change piston. Doug Sapp will
 have new ones.
 Walt
				 Posted: Wed Oct 17, 2007 3:08 pm    Post subject: Prop seals |
				Let me add something to what Walt said if I may.  If you have oil
 leakage coming out of the prop seals it can also come from a leaking
 seal where the oil feed tube is screwed down to the front of the engine.
 There is a gasket under where that tube screws down that you can
 sometimes get to stop leaking simply by applying more torque to the tube
 "nut" (per se). If that fails, you need to replace the gasket.
 Doug, do you have these as well?  I need one myself!
 Mark Bitterlich
 N50YK
				 Posted: Wed Oct 17, 2007 4:49 pm    Post subject: Prop seals |
				Mark,
  Yep sure do, it's part number G1-0017, item #3 on page 125 of vol 2 of the CJ IPBs.   It fits just under the oil transfer tube (on your 50 it's called a "tube nut" I guess) ;o)  Contact me off list and I get one coming your way.
  A note to others, recently I have seen no less than three props which someone had substituted a rubber 0 ring in place of this alu crush seal.  This is a huge No No, on one engine "most" of the 0 ring was found, on the other only a very small piece.  You just gotta wonder............
  Always Yakin,
  Doug
  Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E wrote:
  [quote]   [quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil> (mark.bitterlich(at)navy.mil)  Let me add something to what Walt said if I may.  If you have oil leakage coming out of the prop seals it can also come from a leaking seal where the oil feed tube is screwed down to the front of the engine. There is a gasket under where that tube screws down that you can sometimes get to stop leaking simply by applying more torque to the tube "nut" (per se). If that fails, you need to replace the gasket.    Doug, do you have these as well?  I need one myself!    Mark Bitterlich N50YK     --
