Pilot Eyeball Cooling Vent Location
gareywittich2000(at)yahoo
PostPosted: Tue Oct 16, 2007 5:05 pm    Post subject: Pilot Eyeball Cooling Vent Location Reply with quote
Greetings:
Have RV8-"A". Instr. Panel space ALL used up. Has
anybody mounted their Pilot's Eyeball Cooling Vent
some place other than on the Instr Panel ???
Below Instr Panel (left side) above Throttle Quadrant
can cause inter- ference with Quadrant Levers.
Below center of Instr Panel (between my legs) can
cause interference with the Control Stick.
Below Instr Panel (right side) next to the fuselage
skin limits the visability of some of my Switches /
Circuit Breakers on F8101.
Appreciate any ideas and any pictures would be welcome
too !!!!
Thanks, Garey Wittich Santa Monica, CA (310)
392-1682
Terry Watson
PostPosted: Tue Oct 16, 2007 5:40 pm    Post subject: Pilot Eyeball Cooling Vent Location Reply with quote
I mounted mine below the instrument panel on the left side, forward of the
quadrant and also a little forward of the instrument panel. I also mounted
pull cable controls there for the fuel cut-off, an oil cooler bypass, and an
alternate air bypass to the air cleaner.
It all hanger-flies pretty well. It will be a while before it gets tested in
the air.
Terry
RV-8A #80729 wiring
Seattle
Speedy11(at)aol.com
PostPosted: Wed Oct 17, 2007 8:10 pm    Post subject: Pilot Eyeball Cooling Vent Location Reply with quote
Garey,
Take a look at my web site at http://www.rv-8a.net/2007.htm and scroll down to 22 April to see what I did for air vents. Related posts are on 18 Feb and 12 Mar.
Stan Sutterfield
Spruce Creek Fly-in
S> [quote][b]
mosquito56
PostPosted: Thu Oct 18, 2007 12:17 am    Post subject: Re: Pilot Eyeball Cooling Vent Location Reply with quote
Nice site. I will be studying it for a few weeks to see what Ideas I can steal. Looking good
Don Merritt- Laredo, Tx
