cjpilot710(at)aol.com Guest
				 Posted: Wed Oct 17, 2007 9:11 am    Post subject: the lighter side of tools |
				This is for those of us who really work on our airplanes.  How  many of you will fess-up to this?
  Pappy
  The REAL purpose of tools.......
 DRILL PRESS: A tall  upright machine useful for suddenly snatching flat metal bar stock out of your  hands so that it smacks you in the chest and flings your beer across the room,  splattering it against that freshly-stained heirloom piece you were  drying.
 WIRE WHEEL: Cleans paint off bolts and then throws them somewhere  under the workbench with the speed of light. Also removes fingerprints and  hard-earned guitar calluses from fingers in about the time it takes you to say,  "Yeou - DAM#....!!!"
 ELECTRIC HAND DRILL: Normally used for spinning pop  rivets in their holes until you die of old age.
 CIRCULAR SAW: A portable  cutting tool used to make studs too short.
 PLIERS: Used to round off bolt  heads. Sometimes used in the creation of blood-blisters. The tool most often  used by women.
 BELT SANDER: An electric tool commonly used to convert  minor touch-up jobs into major refinishing jobs.
 HACKSAW: One of a family  of cutting tools built on the Ouija board principle. It transforms human energy  into a crooked, unpredictable motion, and the more you attempt to influence its  course, the more dismal your future becomes.
 VISE-GRIPS: Generally used  after pliers to completely round off bolt heads. If nothing else is available,  they can also be used to transfer intense welding heat to the palm of your  hand.
 WELDING GLOVES: Heavy duty leather gloves used to prolong the  conduction of intense welding heat to the palm of your hand.
 OXYACETYLENE  TORCH: Used almost entirely for lighting various flammable objects in your shop  on fire. Also handy for igniting the grease inside the wheel hub you want the  bearing race out of.
 WHITWORTH SOCKETS: Once used for working on older  British cars and motorcycles, they are now used mainly for impersonating that  9/16 or 1½ socket you've been searching for the last 45 minutes.
 TABLE  SAW: A large stationary power tool commonly used to launch wood projectiles for  testing wall integrity.
 HYDRAULIC FLOOR JACK: Used for lowering an  automobile to the ground after you have installed your new brake shoes, trapping  the jack handle firmly under the bumper.
 EIGHT-FOOT LONG YELLOW PINE 2X4:  Used for levering an automobile upward off of a trapped hydraulic jack  handle.
 TWEEZERS: A tool for removing wood splinters and wire wheel  wires.
 E-Z OUT BOLT AND STUD EXTRACTOR: A tool 10 times harder than any  known drill bit that snaps neatly off in bolt holes, thereby ending any possible  future use.
 RADIAL ARM SAW: A large stationary power saw primarily used  by most shops to scare neophytes into choosing another line of  work.
 TWO-TON ENGINE HOIST: A tool for testing the maximum tensile  strength of everything you forgot to disconnect.
 CRAFTSMAN 1/2 x 24-INCH  SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined  screwdriver tip on the end opposite the handle.
 AVIATION METAL SNIPS: See  hacksaw.
 TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes  called a drop light, it is a good source of vitamin D, "the sunshine vitamin",  which is not otherwise found under cars at night. Health benefits aside, its  main purpose is to consume 40-watt light bulbs at about the same rate that 105mm  howitzer shells might be used during, say, the first few hours of the Battle of  the Bulge. More often dark than light, its name is somewhat  misleading.
 PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals  under lids and for opening old-style paper-and-tin oil cans and splashing oil on  your shirt; but can also be used, as the name implies, to strip out Phillips  screw heads. Women excel at using this tool.
 BLADE SCREWDRIVER: A tool  for opening paint cans. Sometimes used to convert common slotted screws into  non-removable screws.
 AIR COMPRESSOR: A machine that takes energy  produced in a coal-burning power plant 200 miles away and transforms it into  compressed air that travels by hose to a Chicago Pneumatic impact wrench that  grips rusty bolts which were last over-tightened 30 years ago by someone at  Ford, and instantly rounds off their heads. Also used to quickly snap off lug  nuts.
 PRY BAR: A tool used to crumple the metal surrounding that clip or  bracket you needed to remove in order to replace a 50 cent part.
 HOSE  CUTTER: A tool used to make hoses too short.
 HAMMER: Originally employed  as a weapon of war, the hammer nowadays is used as a kind of divining rod to  locate the most expensive parts adjacent to the object we are trying to hit.  Women primarily use it to make gaping holes in walls when hanging  pictures.
 BOX CUTTER: Used to open and slice through the contents of  cardboard cartons delivered to your front door; works particularly well on  contents such as seats, vinyl records, liquids in plastic bottles, collector  magazines, refund checks, and rubber or plastic parts. Especially useful for  slicing work clothes, but only while in use.
 DAMMIT TOOL: Any handy tool  that you grab and throw across the garage while yelling "DAMMIT" at the top of  your lungs. It is also, most often, the next tool that you will  need.
  TOM MASON
 See what's  [quote][b]
