		echristley(at)nc.rr.com Guest
				 Posted: Wed Oct 17, 2007 7:48 am    Post subject: RG-174? |
				I built a transponder antennae, and the plans I used called for using a
 surface mount SMA connector.  Good enough, but now to get cable to match
 to it.  I happened to have a spare antennae for my wireless router, with
 an SMA connector on one end.  Inspect the cable, and it's RG-174.
 I haven't a clue what RG-174 is.
 Google-time.  Search for "coax cable RG-174".  The first hit is an ad,
 but the second one appears to be REAL information.  John Bryant and Bill
 Bowers (didn't he design some antennae for airplanes?) ran some tests on
 the stuff.  Appears that using it could cost you a dB...if you need
 100ft.  I need about 8, and I could make it shorter if I HAD to.
 So the question.  Is there any reason NOT to use this thin, light, cheap
 cable?
 Just to take the obvious off the table:
 It can be delicate...Fix that with proper routing and strain relief.
 Those connectors are awfully small for my fat fingers...Deal with it,
 and do it over till you get it right.
 I'm thinking I will do good to cut the cable off this antennae since it
 already has the SMA connector and I know it works.
		mprather(at)spro.net Guest
				 Posted: Wed Oct 17, 2007 8:58 am    Post subject: RG-174? |
				Why not use surface mount BNC connector?  Or, why not use an SMA connector
 on the end of RG-400.  I think one of the connectors listed on this page
 might work:
 http://www.smelectronics.us/smacableconnectorsa.htm
 Then again, you can buy premade cables with SMA on one end and BNC on the
 other.  Eliminates the need to find correct crimp tools.  If it's RG-174,
 as you pointed out, the losses will be small for short runs.
 Matt-
  <echristley(at)nc.rr.com>
  cable?
				 Posted: Wed Oct 17, 2007 11:45 am    Post subject: RG-174? |
				Matt Prather wrote:
 The plans said to use SMA.  The antennae is awfully small, and so the
 SMA didn't seem like a half bad idea.
 http://ernest.isa-geek.org/Delta/Pictures/TransponderAntennae.jpg
 Most of all, I think you missed the part where I said I have a cable in
 hand. 8*) Changing to BNC might be a good experiment...except that I
 already have a cable in my hand.
 The question was directed more at the suitability of RG-174.  There's a
 lot of back and forth about RG-58 vs RG-400, but RG-174 I've not heard
 about.  It is MUCH thinner, more flexible, no more expensive, just as
 available (now that the RatShack is useless and everything is ordered
 off the internet anyway) and lighter.  I'm looking for a solid reason
 NOT to use it, because I've not heard about it and those unknown
 unknowns are the ones that will get you killed.  Other than that minor
 detail, it looks like a winner all the way around.
				 Posted: Wed Oct 17, 2007 12:28 pm    Post subject: RG-174? |
				Sorry, I did miss the fact that you already have a cable..  If it's not
 too difficult to swap it later, I'd try running the cable you already have
 - it's paid for.  If the performance isn't acceptable, change it for
 something lower loss at TXP frequency.  I notice that around 1000MHz,
 RG-174 is significantly more lossy than the larger diameter cables..
 There will be a measurable drop in radiated power (if you chose to look),
 but that might not affect system performance noticeably.  TXP works line
 of sight, and the ground station antennas are likely pretty well
 optimized.
 Matt-
  Matt Prather wrote:
 > <mprather(at)spro.net>
 > connector
