Distributor cap and rotor
Lynn Matteson
PostPosted: Wed Oct 17, 2007 1:09 pm    Post subject: Distributor cap and rotor Reply with quote
I just replaced the caps and rotors on my 2200, and decided to have
some fun with the old parts. I bored 3/4" holes into one cap between
the four spark plug wire terminals, and hogged out as much material
as I could and still retain the strength of the cap. I then installed
the cap and wires and fired up the engine. Using my digital camera, I
got one shot out of the seven I took which showed the spark jumping
the gap from the rotor to one of the segments...no big deal, just for
my amusement.
Lynn Matteson
Grass Lake, Michigan
flying w/420+ hrs
Lynn
Kitfox IV-Jabiru 2200
N369LM
info(at)usjabiru.com
PostPosted: Wed Oct 17, 2007 1:44 pm    Post subject: Distributor cap and rotor Reply with quote
Lynn,
I'd like to see that photo!
Pete Krotje
Jabiru USA Sport Aircraft, LLC
Lynn Matteson
PostPosted: Wed Oct 17, 2007 5:34 pm    Post subject: Distributor cap and rotor Reply with quote
It's on its way to you, Pete.
Lynn
On Oct 17, 2007, at 5:44 PM, Jabiru USA wrote:
<info(at)usjabiru.com>
Lynn,
Pete Krotje
Lynn
N369LM
gaman(at)att.net
PostPosted: Thu Oct 18, 2007 5:27 am    Post subject: Distributor cap and rotor Reply with quote
Good day,
I have been following the postings but may still need some info. I have an early 2200 w/economy tuning I believe,Only 1 groove in the needle.My Exhaust temps get near 1500 in cruise on cold mornings 1410 during the summer.I am uncomfortable with these numbers and prefer temps in the 1300 range.Cyl heads show just under 300.low speed adjustments are super sensitive,with temp changes.Can I fatten it up a little
Thanx Gary Aman
Lynn Matteson <lynnmatt(at)jps.net> wrote:[quote] --> JabiruEngine-List message posted by: Lynn Matteson
Lynn
[quote] --> JabiruEngine-List message posted by: "Jabiru USA"
Lynn,
Pete Krotje
PostPosted: Thu Oct 18, 2007 7:15 am    Post subject: Distributor cap and rotor Reply with quote
Gary,
You can place a small washer (1/8 diameter or a washer from a #8 screw) under the clip on the needle. That will hold the needle slightly higher in the jet and create a richer mixture. Aim for a cruise EGT of 1350 to 1400
Pete
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of gary aman
Sent: Thursday, October 18, 2007 8:27 AM
Subject: Re: JabiruEngine-List: Distributor cap and rotor
Good day,
� Thanx Gary Aman
Lynn
> Lynn,
> Pete Krotje
gaman(at)att.net
PostPosted: Thu Oct 18, 2007 1:23 pm    Post subject: Distributor cap and rotor Reply with quote
Thanks Pete,I'll give it a try.
G Aman
Jabiru USA <info(at)usjabiru.com> wrote:[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> Gary,
Pete
Subject: Re: Distributor cap and rotor
Good day,
Thanx Gary Aman
Lynn
> Lynn,
> Pete Krotje
