Econo jetting
gaman(at)att.net
PostPosted: Fri Oct 19, 2007 9:55 am    Post subject: Econo jetting Reply with quote
I think the last person to respond to my inquiry was Pete.Based on that assumption I would pose this question.2200 tuning info on line suggests 45 idle jet,250 main jet.276 needle jet and jabiru special needle.The markings on my main jet indicate 175,along with some etched symbols I can't identify.Any chance the factory rebored this 175 to make it a 250?The hole in this jet is .089
Thanks G.Aman
jetboy
PostPosted: Fri Oct 19, 2007 12:45 pm    Post subject: Re: Econo jetting Reply with quote
Hi,
you should download the current information JSL 002-2 april 2007 standard parts are idle jet .35mm needle jet 2.85mm main jet 2.25mm with the revised needle pt. no. 4A131AOD.
I dont know if the previous needle is compatible with this latest revision,
I've had no problems in drilling out my earlier econo jets with metric drills of those sizes although an EGT audit afterwards showed that in cruise my mixture was over rich so I put back an original 2.76 needle jet to get the target readings.
Problems with routing of carb vent line or air intake to the carb will make a difference to tuning so be sure they are correct first.
Ralph
Ralph - CH701 / 2200a
Lynn Matteson
PostPosted: Fri Oct 19, 2007 1:33 pm    Post subject: Econo jetting Reply with quote
That information, (JSL 002) has been "superseded" (my choice of a
word) by JSB 018-1. According to JSB 018-1 paragraph 2.2:
"Accordingly Service Letter JSB 002 has been cancelled and this
Service Bulletin issued in it's place."
I don't know what constitutes a Service Letter versus a Service
Bulletin, and it's apparent Jabiru doesn't either because they
interchange them at will, but that's what came down the pipeline just
recently...October 5, 2007, according to the download that I have.
Lynn Matteson
Grass Lake, Michigan
flying w/420+ hrs
On Oct 19, 2007, at 4:46 PM, jetboy wrote:
<sanson.r(at)xtra.co.nz>
Hi,
revision,
Ralph
Lynn
Kitfox IV-Jabiru 2200
N369LM
gaman(at)att.net
PostPosted: Fri Oct 19, 2007 2:22 pm    Post subject: Econo jetting Reply with quote
Ralph,
Thanks,I had an older copy of the first econo kit and not everything matched up. A little easier to tune with bing parts,but we can handle it.Thanks again
G.Aman
jetboy <sanson.r(at)xtra.co.nz> wrote:[quote] --> JabiruEngine-List message posted by: "jetboy"
Hi,
I've had no problems in drilling out my earlier econo jets with metric drills of those sizes although an EGT audit afterwards showed [quote][b]
