Strobe cable
jpx(at)qenesis.com
PostPosted: Thu Oct 18, 2007 6:38 pm    Post subject: Strobe cable Reply with quote
I am looking to buy 3 conductor shielded 16 gauge wire for my wing tip
strobes.
I have been looking for M27500-16TE3T14 but can only find M27500-16TG3T14.
Looking at wire specs, it is difficult to see differences.
I think the main difference between the two is that TE wire has
M22759/16 wires, which have thicker insulation than TG wire with
M22759/18 wires.
Since the wires are protected inside the jacket, does the insulation
thickness matter for my purposes ?
Jeff Page
Dream Aircraft Tundra #10
n744bh(at)bellsouth.net
PostPosted: Thu Oct 18, 2007 6:54 pm    Post subject: Strobe cable Reply with quote
Jeff,
Check http://strobeguy.safeshopper.com/32/cat32.htm?620
Give him a call and see if what he sells is what you want. I've only done
business with him one time but was very satisfied and he did save me a few
dollars.
Bill
Glasair SIIS-FT
nuckolls.bob(at)cox.net
PostPosted: Fri Oct 19, 2007 5:06 am    Post subject: Strobe cable Reply with quote
strobes.
As far as I know, the wire shipped in factory kits for
strobe installation has been a Belden product having
100% coverage, "Beldfoil" shield. These products
are described in the documents you'll find at:
http://www.aeroelectric.com/Mfgr_Data/Wire/Belden/
M22759/18 wires.
No, either of those wires would do. The wire gage
isn't really critical either. Voltage drop in smaller
even smaller wires is insignificant for these
installations. The insulation for Belden wire
is PVC over Polyethylene. This is admittedly
a "1960s" wire product but has proven successful
in hundreds of thousands of aircraft. This is
a low energy circuit that doesn't need
fault protection for the installed wires so
spending much $time$ acquiring a more exotic
wire product may not be well invested.
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
PostPosted: Fri Oct 19, 2007 5:26 am    Post subject: Strobe cable Reply with quote
At 09:52 PM 10/18/2007 -0500, you wrote:
Jeff,
dollars.
The wire illustrated at
http://strobeguy.safeshopper.com/32/1922.htm?248
appears to be the Belden product I cited earlier.
. . . and the price is certainly right! A Belden
distributor will want to sell you a 1000' at
about 5 cents per foot.
jpx(at)qenesis.com
PostPosted: Fri Oct 19, 2007 7:19 pm    Post subject: Strobe Cable Reply with quote
Bob,
Your first answer is what I really needed. I have been putting
together a list of all the wire I expect I will need (probably as
accurate as a weather forecast).
I want to buy everything at once from a single vendor, which reduces
shipping and brokerage charges to Canada significantly.
I have been amazed at how many vendors really don't have common sizes
and colors in stock. One of the largest Canadian vendors has only 10%
of what I need in stock Sad
Wire Masters has everything, expect they have to substitute
M27500-16TG3T14 for the TE that I requested. Since the thinner
insulation is ok, then I can place my order.
Jeff
Jeff,
only done business with him one time but was very satisfied and he
did save me a few dollars.
strobes.
M22759/18 wires.
